Question about Gateway GT5220 PC Desktop
When i turn on my pc i get no picture what video card do i need to get
  • joecoolvette
    joecoolvette Jul 05, 2010
    Suggest you diagnose something else first, and not assume it's the Integrated Graphics on the motherboard. (Integrated Nvidia GeForce 6150LE. This is a GPU soldered to the motherboard, not a Graphics Processing Unit, soldered to a removable graphics card) . (http://support.gateway.com/s/PC/R/100915... ) It could be you have a bad Power Supply. Weak Voltage power rail. 1) ALL the LED lights together use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts of power. 3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is. The Gateway GT5220 comes with an AMD Athlon 64 X2 3800+, that uses an AM2 processor socket. This Processor can use up to 89 Watts. (http://en.wikipedia.org/wiki/List_of_AMD... This is why you may see LED lights light, fans spin, and maybe even hear the harddrive spinning, but there isn't enough power to turn the Processor on. No Processor running, No Computer. Therefore No Video Signal to the monitor. Suggest you test the 12 Volt power rail of the Power Supply, before looking into purchasing a graphics card. Need to know how, post in a Comment.
    Sergeant:
  • 249 Answers
That only depends on how much money you want to spend really. The thing that nees to be matched with a video card is the power supply. Look at the specs on the video card, and it will recommend a certain wattage of power supply. Or, you can start by looking what wattage power supply you do have, and then google "what video cards will my xxxWatt power supply support"...or something like that.
Some other things to consider with a video card..Do you want to do anything special? Hook up 2 monitors at once? Get one with 2 DVI (or vga, whatever type connectors your monitor has) connectors.
Also, video cards come with different amounts of memory on them. This memory is usable on your system just like your ram. It's just something to be aware of...256Mb, or 1Gb, I'm not sure if they are up to 2Gb yet, it's been a year since I bought one...but that's another thing to look at when buying one.
But for compatibility, it's just the power.
If this post has helped, please remember to vote....
Posted on Jul 04, 2010
  • Donna Sander Jul 05, 2010
    And maybe I took this for the obvious and probably shouldn't have. Make sure the monitor is good. Connect another monitor to it first, then check it with another cable and also take a good look at the pins on the connector and make sure nothing is bent or broken. Don't do anything to the computer until you verify the monitor is good.
    Please vote if this post helped.
Windows 7 refused to update. Windows 7 refuses to
  1. Do one of the following:
    • Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
    • Connect a portable device that contains pictures or videos to your computer by using the device's USB cable, and then turn on the device.
    • Insert a removable flash memory card, such as a Secure Digital (SD) or CompactFlash memory card into a memory card reader.
    • Connect a scanner to your computer by using a USB cable, and then turn on the scanner.
    • Insert a data CD or DVD that contains pictures or videos into your CD/DVD drive.
  2. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  3. To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
  4. Change one or more settings in the Import Settings dialog box, and then click OK.
  5. Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then clickImport to import your pictures and videos using the new settings.
    For updates make sure that the time and date are correct, if it doesn't match what time it actually is , it wont update, and make sure your OS has been activated
Aug 29, 2013 | Dell Dimension 4700 PC Desktop
My camera memory card shows its full but when i using it on pc it shows empty. what to do? i need this pictures n videos... help me...
The card has corrupted. You'll likely need to use recovery software (see this article). After recovery, youmay need to format the card in your camera to correct the corruption.
Dec 11, 2012 | Nikon D3100 Digital Camera
I believe my video card is going again, I have to turn off the monitor, and turn it back on and it only comes on for a second literally, I did flashlight test, I can see the icons as if it were a very dim...
You said you can see the icons on the display in very low light, that would be that either you need to adjust the display settings or the display is defective and not your video card, as if the video card was defective there would be nothing on your display.
Try connecting a known working monitor to your pc and see is that works normally, to prove that the video card is working normally.
You can copy the picturs on a flash memory drive or to the laptop if your laptop is connected to the same network that your dektop is.
I hope this helped.
Good luck and have a pleasent day.
Jun 21, 2011 | HP FK790AA Pavilion Elite m9400f Desktop...
The pc turns on but no image on screen sometimes,have changed memory modules.its seeing well you restart it and then no image,but pc is on
For a desktop, first try the monitor on another computer, preferably with a different video cable. If it doesn't show a picture; the fault is probably at the monitor. Also try a different monitor on the Gateway.
If these two tests show that the monitor is bad, replace it to use your computer for now. (If it is under warranty, consider warranty repair. Otherwise we can try to diagnose the problem. (Common problems for an LCD monitor are the power supply, the backlight, the backlight inverter or the main board itself. The inverter is the easiest part to replace and can be tested with an oscilliscope or a multi-meter that can measure several thousand Hz.)
If you get a picture, try the monitor on the first computer with the second video cable to rule out a bad cable.
If there is still no picture, the next step is to determine if the computer has a video card installed or if you are using the on-board video. Many computers have both so try plugging the monitor into the other ports if there are any. (The on-board video is disabled when you have a video card in place. When reconnecting the cables, it can be easy to plug into the wrong spot.) Check if the monitor is working.
Replace the video card with one appropriate for your computer (you will need the specs for your computer's PSU (original specs - 300W) and card slot (PCIe x16)). You need a card that doesn't require more power than the power supply can put out. (Remember the CPU and other components need power too. Card specs will include the recommended minimum power supply needed to run the card.)
If you can, get a card that matches the existing video card. This will avoid a major problem. You need to uninstall the current video card drivers to put in a new one. You can try booting into Safe Mode by pressing F8 as you power up the computer. (This can take several tries to catch the point where the computer looks for the keystroke. You only have a few seconds.)
If you have been using the on-board graphics, get a video card. You will need to press a key (F1 or F2 for most Gateways) to enter the BIOS then disable the on-board graphics when you install the new card.
I hope this helps.
Mar 30, 2011 | Gateway GT5438 PC Desktop
Monitor is OK but when turned on the screen is black with a little square that has a message "Dell, No input signal". How can you repair this.
Monitor is not getting signal - picture from pc. Did this ever work or is this new pc? Is PC running? Does it do more than just blow fans? Like hard drive spinning up etc.. Check your video cable connections. Turn off monitor and pc first. Remove and re plug both ends of the video cable. Look for bent pins in plug ends before re pluging. Try a different cable if possible. If not fixed, you may need a new video card. Is this a pc that was working and suddenly failed? Either the pc is not running, or the video card is failed.
Nov 09, 2010 | Computers & Internet
When I turn on the power on my thinkpad the picture on the monitor is garbled and it's almost near impossible to get it ungarbled. It does it right when it starts up
connect an external monitor and check how is the display,if the display is fine on external monitor,then it would be your
LCD OR VIDEO CONNECTION OR CABLE NEED TO CHECK .
If you are getting the garbled picture on the external monitor also it could be
SHARED MEMORY AT FAULT( If the laptop uses shared video memory (part of the main memory is used for the video purposes), it's possible that you have a faulty RAM stick.)
OR
VIDEO CARD (if the video card is discrete replace take out that and check the video with integrated video card and if the video card is integrated then you have to replace the mother board)
Sep 17, 2010 | IBM ThinkPad A31 Notebook
Flashing screen with loss of picture
Try to turn off your laptop, remove the cables on the pc. Press and hold the power button for 8 seconds, then reinsert the cables and battery on your laptop. Turn on the pc and if you still have the flashing screen with loss of picture, there might be a problem with the video card. If you don't know how to reseat the video card, consult the pc manufacturer.
Jul 04, 2010 | HP G70t Notebook PC
Computer turns on but i have no image on monitor
If your monitor is working, try taking all add-on cards out of your system to see if your monitor comes on. (Sound cards, modem, Network cards, etc.) If after doing this you still get no picture, very strong possibility your video card (on-board) is bad.
Feb 02, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Monitor problem
Hello soltaino, your board (K7VT2), did not come with a video card. (New). If you have a video card in your PC it was added. I'll need to know the name of the card to advise you regarding a cable to connect to the monitor. My guess is it's like the pictures listed below.
The Asrock does have an AGP 4x video slot. If your board has a video card installed it's connector would connect to a standard VGA connector at both the monitor & at the video card.
Whick looks like this.
The picture above shows a female VGA port, (like on a monitor).
b9662ed.jpg See the bue cable. That's a standard SVGA cable connector.
If you can not connect to the PC you need a new video card, not a new monitor. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3667003&CatId=876
Suggest this card. It has both VGA & DVI connectores.
Best Regards!
Mike
Apr 01, 2008 | Asrock K7VT2 Motherboard
Screen picture turn side ways!
It would appear that you managed to press CTRL + ALT + Left Arrow.
To correct this problem simply click CTRL + ALT + Up Arrow
If you have a video card installed, then the option menu for that card should be accessed. You can always post it here if you have a video card and the model #s, I can help you if the above does not work.
Nov 19, 2007 | E-Machines eMachines Desktop PC
Gateway GT5220 PC Desktop Logo
208 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
