Question about Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator
Replace parts for hand brake for winnie nannie deluxe walker
Winnie the pooh walker safety 1st
Hi
We would request that you contact our USA customer care team directly for assistance -
Jul 12, 2014 | Safety 1st Acella LX Winnie the Pooh...
How to adjust brakes
Hi.can you tell me how to ajust front calipers on BA Falcon on 2003 6 cyl. thanks.
Jan 01, 2014 | Drive Medical Winnie Walker, Mimi Lite...
How to adjust parking brake on winnie lite 3 wheel rollator
For openers "LOCKING" handles)...
Very GENTLY would be the first caution..
Unlike the brakes on those long ago bicycles we used to have... these WALKER BRAKES are pretty cheesy plastic...
None of the ones I've been compelled to work with have
interchangeable parts... SO BE GENTLE.
Look at both ends of the cable of the first wheel you want to adjust...
You are looking for a threaded sleeve with a nut on it...
If the brakes are too tight you will want to shorten the sleeve...
Too loose you will want to lengthen it (tightening the cable).
DO NOT overtighten...
These are all plastic... cheaply constructed... but EXPENSIVE to replace.
I have had to hand craft REPLACEMENT PARTS to repair these things (nothing is STANDARD (but the careless attitudes).
When you do break'em... AMAZON had the greatest selection...
(knowing the mounting diameter, and cable length is imperative
(sold in PAIRS)).
Carnac the Magnificent
Jun 20, 2012 | Drive Winnie Lite Supreme 3 Wheel Rollator...
How do you change the battery in the safety 1st winnie the pooh walker
Go to the Safety 1st site here:
http://www.safety1st.com/usa/eng/
At the bottom right is the customer support link for instructions. You will need the product number. If you do not have that you may need to use the Contact Us link for further assistance.
Thanks for using Fixya.
Jul 30, 2011 | Winnie the Pooh Toys
The brakes on a clever lite rolling walker will not engage when the grips are squeezed
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. Hope this helps.
Nov 09, 2010 | Drive Medical Winnie Walker, Mimi Lite...
I need the intruction manual to the Safety 1st Winnie The Pooh Walker
Ask the place you brought it from they shoudl be able to help you please.
Jun 19, 2010 | Safety 1st Acella LX Winnie the Pooh...
Broken brake cable.Where do I get a replacement?
Hi. I repair walkers wheelchairs and mobility scooters. I sometimes get asked to repair broken brake cables on walkers and wheelchairs. I get new cables from the local bicycle repair shop. Take in your old cable so they can measure its lenght, and find one the same. They only cost a few dollars.
Good luck. Neil.
Jun 07, 2010 | Medline MDS808210AB ExcelT Deluxe Aluminum...
Need to adjust the brakes on a Winnie Walker Lite Deluxe walker.
Please try :Instruction Manuals.Visit :-www.FixYa.com/Instruction+Manuals
May 12, 2010 | Drive Medical Winnie Walker, Mimi Lite...
Replacement parts for disney winnie the pooh baby walker model 04028 dhn .... looking for 2 toys that are attached to the trays
missing globe on winny the pooh modle #wa030nab.
are there replacement globes that can be purched?
Aug 08, 2009 | Toys
Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator Logo
443 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
