Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Home signal interruption for an hour each day
I have a boom box with the home antenna outside. Every day at the same time, about 4:00 pm EST the signal cuts out for an hour. Even when I move the antenna I can't get a signal. Has anyone else experienced and resolved this problem? Thanks.
  • 1 more comment
  • Rbrucec Jun 11, 2008
    I still have the problem. I live north of Boston on the New Hampshire border.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this problem still going on?
  • Jeff Stevens May 11, 2010
    Where in the US do you live? The satellites are positioned in a particular area of the sky and orbit in a specific pattern. Antenna aiming is very important.
The problem is still going on. I live north of Boston on the New Hampshire border.
Posted on Jun 11, 2008
I Home clock radio time zone change. The I-Home clock radio did not change from DST to EST on Saturday evening at 2 AM
If it needs a Radio Signal to change TIME , try 2 things..
1 switch clock off, wait 30 seconds, then switch on. See if that works !
2 Put Clock near a window, or even better outside, as sometime Clock Radio signal will not be strong enough in the house
Nov 06, 2017 | The Audio Players & Recorders
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
Can i just get a phone number I can call where I dont get hung up on for support. i am not a electronics type of person and i need to talk with someone.
No one can guarantee what another will do to you on the phone.
Here's Panasonic's Phone Support page...
http://www2.panasonic.com/consumer-electronics/support/Contact-Us.1
Product Support and Technical Assistance
1-800-211-PANA (7262)
en Español opcion #2
Hours
Mon-Fri 9:00 AM - 9:00 PM EST
Sat-Sun 10:00 AM - 7:00 PM EST
May 18, 2011 | Panasonic Home Theater System System
The signal will be fine for a while, then I get a "no signal" message...I usually get this after the radio has been on for a time
Hello
Please send me the model number of your Sirus Satellite Radio, and let me know whether can I place a solution before you. Ok.
Apr 02, 2011 | Sirius Satellite Radio Receiver
Need a remote
You will need to contact customer service to see if they can ship you another one, or where you can purchase a replacement. Below is their customer service info from the 937 manual. Best of luck...
Hours: Monday to Friday, 8:30 AM-11:00 PM EST
Saturday to Sunday, 9:00 AM-11:00 PM EST
Email: techsupport@cobyusa.com
Phone: 800-681-2629 or 718-416-3197
Web: www.cobyusa.com
Apr 11, 2010 | Coby DVD-937 5.1 Channel DVD...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
78 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
