Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Our TV is 7 years old and we recenly replaced te HD cable box. Now, we have a problem with the red color (or lack of it). Can you help us? Thanks!
  • 201 Answers
If you are using a component cable for HD (5 wires) a common problem is mixing up the red video and red audio wires. start over and make sure each wire goes where it should and that they are pushed in all the way. Having a wire only slightly in is another common problem. good luck.
Posted on Jul 05, 2010
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
No red when hooking up component cable for dlp hd tv. Only blue and green colors show on hd component input for charter hd cable box. Are there any internal adjustments that need to be made through either...
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
Nov 03, 2009 | JVC HD-61Z456 Television
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Getting the VCR to play through the old Philips TV
Looks as if you were using the AV cable to connect the VCR to TV. The three colored cables should be connected in the following order:
Yellow: From VCR Video out to TV Video In
Red : VCR Audio out (right) to TV audio in (right)
White: From VCR Audio out (left) to TV audio in (left)
Also check the color on the sockets on TV and VCR and match accordingly.
Hope this solves your problem. Thanks
Jul 12, 2009 | Televison & Video
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
Apr 28, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Color fading to black and red "nightvision" picture
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
Oct 03, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
