I have an Equinox ELS II 16 port terminal server, but I can't configure it, can't log into it, can't get my hyperterm to interface to it. Anyone out there work with these???
    Sergeant:
    Champion:
  • 293 Answers
If you know the ip address of the terminal server you can access it using telnet in command prompt
Posted on Apr 17, 2008
How to Configure AAA for Cisco Devices?
Note:The Cisco devices here include all Cisco products, like Cisco routers, Cisco catalyst switches, etc. Also apply to the new 2960XR switch, we configured AAA for the WS-C2960XR-48TS-I and WS-C2960XR-24TS-I. here is the procedure:
http://www.discountroutercenter.com/how-to-configure-aaa-for-cisco-devices/
Dec 02, 2014 | Cisco Computers & Internet
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Cannot configure ip address using add hardware
The IP Address is configured on Control Panel - Network Connections - Local Area Connection - (Right-Click) Properties - Internet Protocol
Hope this helps.
Aug 11, 2009 | IBM Equinox ESP-16 (24P7477) Terminal...
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Mar 16, 2009 | Cisco PIX 501 Firewall
I need to know how to configure link proof radware
Hi Nalinfrancis,
One way you can config the LP is to log on to the serial interface and then configure an IP address to the first eth port that is available. Then connect directly to the port using a crossover cable depending on the laptop or pc that you use if it can switch put your laptop/pc on the same network that you configured on the port. Then connect via your browser to the IP address assigned to the LP. Logging with you default username and password. From there you can do all the configuration via the web interface.
Regards,
Andrevz
Jan 03, 2009 | Radware LinkProof Application (904627-cl3)...
At-8624t
How to Configure the Switch
Some configuration is necessary to enable the switch’s advanced switching
capabilities. This is achieved via the Command Line Interface (CLI). On the
AT-8624T/2M, you can also use the Graphical User Interface (GUI).
Using the CLI to configure a switch
1. Connect a terminal or PC to the Terminal Port (ASYN0).
Using the supplied RS-232 DB9 serial straight-through cable, connect your
terminal or PC to the RS-232 Terminal Port:
• For the AT-8624T/2M and AT-8624PoE, the RS-232 Terminal Port is on
the front panel.
• For the AT-8648T/2SP, the RS-232 Terminal Port is on the back panel.
2. Set the communication parameters.
Set the communication parameters on your terminal or terminal emulation
program to:
• Bit rate: 9600
• Data bits: 8
• Parity: None
• Stop bits: 1
• Flow control: None
3. Log in.
After the switch has booted, the login prompt appears. If the login prompt
does not appear, press [Enter] two or three times.
When the switch boots for the first time it automatically creates an
account with manager privileges. The account has the login name manager
and the password is friend.
At the login prompt, enter the login name and password:
Login: manager
Password: friend
The switch’s command prompt appears. Now use the CLI to configure the
switch.
Using the GUI to configure the AT-8624T/2M switch
This section describes how to establish a connection to the AT-8624T/2M switch
through the GUI so you can configure it before installing it in your LAN.
1. Select a PC to use and identify its subnet.
You can browse to the switch from any PC that is running a supported
operating system with a supported browser installed. JavaScript must be
enabled. If you are using a toolbar or plug-in on your browser to block popups,
disable it while using the GUI. The GUI displays detailed configuration
options and information in pop-up windows.
2. Connect the PC to the switch.
Use an Ethernet cable to connect an Ethernet card on the PC to any one of
the switch ports.
You can browse to the router through any VLAN, as long as you give that
VLAN an IP address. These instructions assume you are using vlan1. All
switch ports belong to vlan1 by default.
3. Access the switch’s command line interface.
Access the CLI from the PC, as described in the previous section, “Using
the CLI to configure a switch”.
Installation & Safety Guide 13
4. Enable IP.
enable ip
5. Assign the vlan1 interface an IP address in the same subnet as the
PC.
add ip interface=vlan1 ip=ipaddress mask=mask
6. Save the configuration and set the switch to use it on bootup.
create config=your-name.cfg
set config=your-name.cfg
7. On the PC’s web browser, bypass the HTTP proxy server, if
necessary.
8. Point your web browser at IP address for vlan1.
9. At the login prompt, enter the user name and password.
User Name: manager <the default>
Password: friend
The System Status page is displayed. Select options from the sidebar menu
to configure and manage the switch.
For context-sensitive online help, click the Help button at the top of the
sidebar menu or on any pop-up page
I hope this helps you out
podum
Sep 01, 2008 | Computers & Internet
VLAN
no competent guys out there ???
Apr 19, 2008 | IFS EtherNav D7600 8-Port Ethernet Switch...
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Setting up an ELS 16 Terminal Server
Have you tried this?
Step1.
DEFINE NODE GATE1 IP (enter gateway ip here) GATEWAY ENABLE
Step 2.
INITIALIZE SERVER
Oct 11, 2007 | Equinox ELS 16 Terminal Server
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
