Question about Creative Labs Zen V MP3 Player
Player Will not turn on
Hi there. I've had my player for quite a few months now, and I've been experienving some strange problems.
The screen on my player occasionally freezes, and I cannot turn it off or plug it into the computer (because it isn't recognized)
I normally just wait until the battery dies and then I plug it in a charge it, and everything is fine again. This has happened about three times.
Now, this time, I was in the middle of listening to a song, and right when the song ended the player's screen turned black as if it was going on sleep mode, but when I pressed a button it would not turn on. This happened last night. I plugged it into the computer this morning after trying to turn it on again, and it isn't recognized. The player won't even turn on in the slightest. The buttons don't even light up. What should I do?
Thanks.
  • Anonymous May 07, 2008
    Player does not respond even after recharging. Black screen...nothing works.
    Thanks in advance
  • grego52 May 13, 2008
    My black 2 gig Zen worked fine lastnite, plugged into the usb overnite, now, nothing, its dead????
    Problem Solver:
  • 5 Answers
If you turned it on before you charged it when you got it, that may be the problem, i would take it back to the store, get a new one, and charge it immidiately and make sure you use the disc to install it
Posted on May 29, 2008
The DVD player on my Dell Inspiron-530S won't work, you can hear it like it's trying to load but the play screen never comes up.
no, your dvd drive has gone bad. to check if it is working or not your try to manually open the content of the cd and try copy on the hard drive. if it copies fine then the cd is good if not cd is bad. you might get a error message of bad sector or data randomization.
if it does not open at all the cd drive is bad. raaj_k001@in.com
Jul 05, 2012 | Dell Computers & Internet
Why is adobe flash player crashing everyday?
Quite often you may have to do the removal and restart your PC. Once you have done that, check your registry to make sure you have removed any traces of flashplayer. Before you edit your registry, make sure you back it up first. Should something go awry, you can go back and recover to the back up registry file. Also make sure you do one product removal at a time and check that the reinstall removed all pieces.
May 01, 2012 | Acer Computers & Internet
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I plug my mp3 player into the computer to charge and it turns off
Run a repair in the Philips Device Manager - make sure the lock switch is disengaged first.
-Tha Mp3 Doctor
Nov 25, 2008 | Philips SA3125\02 MP3 Player
Tobishi In Dash DVD Player
solution , der is a Hand Control cable that needs to be connected to the Ground{negative} cable , once u connect that , done deal....it is back to normal!!!!!
Oct 06, 2008 | Car Audio & Video
Player automatically turns off/on.
Sometimes the standby factory setup (electronically) should be unplugged. In most types of dvd players and other players it's the main problem. It should be taken to a repair tech and fixit, anyway this could not be absolute could be especifically in the power management circuitry. Some times power peaks and other anomalies could kill the standby feature nad reset on and on your dvd.
Dec 09, 2007 | LG DN788
Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Nov 26, 2007 | Philips GoGear HDD075/17 MP3 Player
My screen is messing up
Hi hope this helps. Turn off your e260. Slide the hold switch for it to show red/orange color. Then press the record button and the menu button until you see on the screen of the player "Welcome to Recovery Mode". Now go to the sandisk website and download the firmware update if you have not tried to update the firmware of the player. Run and install it on your computer, when it ask you to connect a device hook your player to the computer and then it will try to look for updates for the player. When it does update the firmware of the player. And also if you can get to the menus of the player you may want to format the player maybe it is your songs causing the problem. Switch the player to MSC then open My Computer and format your player on that window.
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Zen V MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
