Question about Hoover Vacuums
Hoover wind tunnel vaccuum cleaner i need to know
Hoover self propelled premium with wind tunnel vaccuum cleaner i need to know how to put the bigger belt on it EPA-Est.-23781-TX-1 model# U6445-900 serial# 119800057629
Buffalo12980
  • 625 Answers
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Posted on Sep 22, 2007
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel upright self
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
Posted on May 20, 2008
  • 294 Answers
SOURCE: hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Posted on Mar 14, 2009
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
  • 18 Answers
SOURCE: Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Posted on Oct 08, 2009
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled wind tunnel doesn't self propel going backwards.
Your self propel cable sounds like you need to have an adjustment. reccomend a service shop repair.
Sep 25, 2009 | Hoover Vacuums
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Flat belt to hard to stretch
The belt number is 38528035 and it will stretch far enough to go over the bigger pulley.
May 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
71 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
