Question about Weber Genesis Silver B Grill
GENESIS SILVER B NATURAL GRILL
There is a white cable hanging down of the right side near the tank entracnce. Where should this connect to?
  • 1,871 Answers
Hello! It's the spark wire for the side burner...
Guru.................Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on Jul 04, 2010
I just want to know if I can use Charbroil's natural gas conversion kit to convert my Weber Genesis Silver grill.
NO. Weber grills have never been approved for gas conversions.That's why they made/make Natural Gas models & Propane models. Doing so, puts all the liability in your lap, if some thing should go wrong.If you have any doubts, check your Owner's Manual under "Warnings."
Hope this helped to answer your question. Thanks for choosing FixYa.
Aug 27, 2011 | Weber Genesis Silver B Grill
I have Weber Genisi Silver model 8133 which has been hook up to a natural gas line. We have moved to a new location and can only use a propane tank hook up. Do I need a adaption for conversion to...
Unfortunately, you cannot use your Natural Gas Grill on Propane Gas. In addition, there is no conversion kit for Weber Grills. That's why they make two different gas models. Conversion of a grill becomes a safety issue. As each model Weber grill is tested and approved only for the specific gas type. Attempts to convert it voids that approval.
I'm sorry I didn't have better news. Thanks for choosing FixYa.
Jul 27, 2011 | Weber Genesis Silver B Grill
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
Grill is 6 years old, was running great, put new gas tank on line and ran it for an hour only to get to 130 degrees
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 30, 2010 | Weber Genesis Silver C Grill
I have a weber genesis grill. just refilled the tank and connected it. this afternoon my wife smelled gas near the unlit grill. There was also an intermittent hissing sound. could the heat of day 90 plus...
seems like I can always smell a little gas on a freshly filled tank until I use it down a little bit. Also there is a bleed off screw on the valve of the tank Make sure it is tightly closed
Aug 09, 2010 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Natural gas grill needed to convert to propane
You would need to do the old crank down and flip routine. Crank down all spuds, open shutters all the way and flip the regulator nut to the LP position.
I found an interesting video on youtube which features gas stove conversion. Gas range conversion is basically the same.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2010 | Weber Genesis Silver B Grill
Instead of using a propane tank, I've hooked up my grill to natural gas. As a result, my grill does not get as hot as I would like. Is there a different valve I should be using when I'm hooked up to...
WHEN U SWITCH TO NATURAL GAS YOU MUST REPLACE THE GAS VALVE AND IN MOST INSTANCES THE BURNED INLET FIXED ORIFICES, CONTACT THE MANUFACTURER FOR THE PARTS
Jun 12, 2009 | Weber Genesis Silver B Premium Grill
Grill willnot light
there is a blockage in the line!!!
Jun 10, 2009 | Weber Genesis Silver A Grill
Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
May 07, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
