Question about Dishwashers
Is there a micro switch on a dishwasher to let the water in hotpoint hydrocare super plus model no 7822 my machine dosent seem to fill
  • elmo_1991
    elmo_1991 Apr 19, 2013
    mine has the same problm powere is on but no responce at all :(
  • 262 Answers
Most Dishwasher have a flote switch for the water level. You need to check it as well as the water inlet water valve.
Posted on Jul 04, 2010
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
Hotpoint built in dishwasher model no BF72 switches on for a couple of minutes then bleeps and showes error E8, can you tell me what the problem is. Many thanks Phil
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
I have a Hotpoint Super Plus dishwasher 7820. It worked well for a long time. Towards the end of the cycle it leaks a lot of water from the underside of the door, so it seems. I have fitted a new door...
The door seal has to be in a proper position completely around the door (including the bottom area of the door). If not, it will leak. Also, there are two black corner baffles/seals (located in each front corner inside the tub area) that may also be the culprit. Additionally, there may be an issue with the float switch assembly that shuts off the water supply prior to the wash cycle. If the float switch assembly is allowing an extra amount of water in the tub, it will cause a leak.
Feb 26, 2010 | Hotpoint Dishwashers
I have a Superplus Hotpoint dishwasher model no.7822. After normal wash there is still water about an inch deep left at the base of the machine. What can the reason be?
Hi.
The filter basket in the bottom could be blocked, but it is more likely the outlet hose having become full of foul smelling gunge.
You could try filling the machine with very hot water and plenty of dishwashing detergent, running it without dishes for ten minutes and then pumping it out to get plenty of hot detergenty into the drain pipe.
If you want to be economical you could aim the drain pipe into a bucket on a chair to catch the emerging water and go through the process a few times to try to clean out the pipe without wasting water or detergent or energy.
The contents of the bucket after the first run will give you an idea if you are on the right track.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Jul 01, 2008 | Dishwashers
Dishwasher not filling
there is a small float and micro switch behind the LHS cover which if activated will stop the water flow. you will need to remove the top cover(dont forget to unplug from the mains first !). then remove the side cover, you should find a clear plastic unit with a red float in side this maybe gumed up with scale. if so you should clean to allow the float to be free. this float activates a micro switch via a red arm. if this switch is stuck in this will stop the water flow. or the switch maybe faulty.
May 31, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher leak
must need a new air tube or worse still the air chamber has a split in it
clean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Jan 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
Owen Barnes
