Question about Dryers
Maytag Atlantis gas dryer Model # MDG7658AWW. No longer heats up. Would like to fix it myself if possible as it is no longer under warranty and can't really afford a repair man at this time. Worked just fine the other day but won't heat up at all now. I have removed and replaced the venting to outside so that is completely clear (clog free) but that has not solved the problem. What part do I need to replace and where is it located.thanks
Washer_tech
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
  • 22 Answers
SOURCE: MAYTAG ATLANTIS GAS DRYER # MDG7600 aww
sounds like you need an igniter
Posted on Aug 22, 2008
  • 686 Answers
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Posted on Feb 18, 2009
GM Elec
  • 1000 Answers
SOURCE: how do i side vent my maytag atlantis electric
Attached is a link to a diagram of your dryer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170653
You would have to remove the back panel. Remove the existing vent pipe, install a 90 deg elbow of the same size diameter. Then cut a hole in the right or left side of the dryer cabinet that would line up with the new elbow.
Check the side cabnet of your dryer, it appears on the diagram that there may be a 4" knock out for a side exit vent.
Good luck, let me know.
Regards,
Posted on Jul 21, 2009
  • 10865 Answers
SOURCE: not getting hot. vent line is free of lint. Maytag
Chances are the hot surface glow igniter is not working. Most likely it is burned out. Set the controls to dry in high heat and note if the glowing coil does in fact glow. If not, it needs to be replaced. Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow. If all the controls are set correctly on the front control panel and the dryer is running, but the glow coil fails to glow, you've located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. The nut on the gas valve to remove it from the gas supply pipe turns counter clockwise. There will be small sheet metal screws used to secure the plate to which the burner assembly parts are attached. The plate holds the entire assembly and is attached to the bottom of the dryer's cabinet.
Next, remove the glow coil from the burner assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil. Glow igniters are fragile and they break easily. Handle and install the new igniter carefully. Glow igniters are a non-returnable and non-refundable electric component.
Be advised that some new replacement igniters do not come with quick disconnect ends. In this case, it is OK to cut off the quick, disconnect from the old igniter and attach it to the new igniter. Simply clip off the wires several inches above, disconnect the old igniter, attach to the wires of the new igniter, and wire nut the two ends together. Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative polarity to be concerned with.
Additional Suggestions: Read the manufacturer's online Web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair procedures, instructions, pictorials and schematics, which may be available online.
Posted on Oct 15, 2009
I have a Maytag gas dryer MDG7658AWW. It heats but timer won't advance in any setting. I have taken the screws out of the moisture sensor and cleaned it both front and back and removed any lint from...
You either have an issue with your cycling thermostat, or the gas valve solenoids. I could get into a very lengthy explanation as to what to do to diagnose, but for what these two items will probably cost you to buy, I would change both.
Oct 15, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dryer not heating up
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Jan 20, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
The Maytag Atlantis dryer (gas) does not appear to be igniting the burner when it is turned on. The problem has gradually become more frequent over the last couple weeks. Now, it almost never lights up. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have a Maytag Atlantis. Model#- MDG7658AWW gas dryer. My issue is that the dryer starts to heat up ( the way it should ) at the begining of any cycle but cuts the flame after one minute & the dryer...
Problem is not with the thermals. You gas coils on the valve have gone bad. Replace both of them and you will be fine. Very inexpensive repair. Part number is 12001349 at approx. $45.00.
Jan 31, 2010 | Dryers
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My atlantis MDE7600ayw is taking two cyles to dry
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Jan 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer takes a long time to dry clothes
listen,a dryer either heats or does not heat no in between,either your dryer vent is clogged up and into the dryer or your outlet is not giving the proper voltage.let me know what you find,thanks-mike
Jul 14, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MAYTAG atlantis MDG6400AW, dryer not heating
no we can fix it its proab a heatyer coil or thermial limiter if you reply ill help mater of fact did you have it on auto dry ?
Apr 03, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Oct 22, 2007 | Dryers
Dryers Logo
184 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
