Question about Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow
I have a bushnell elite 323951m command post reticle ...the crosshair part is broken the cpr part is ok i think bushnell cant fix it , the scope has been discontinued any idea where i may be able to get the scope fixed
How to repalce the crosshairs
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Jan 23, 2013 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Scope wont shoot good groups
That can get expensive, I had the same problem, bought a Bushnell scope and it went everywhere but on the target, couldn't hold it steady, with my win mod 70 in 308 with heavy barrel, I said that's it, I went and bought a Leupold, no problems since. I don't know what was wrong with the Bushnell, just couldn't handle the blast I guess. I put he Bushnell on my bolt action 223 and haven't had a problem with it, but always expect one because of what happened before. I don't remember the model number, but it was a 3x9. Hope this helps.
Jun 20, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Hi Iv'e got a Bushnell 4x32 scope that needs a new set of Crosshairs were can I get these from??????? Cheers Rob.
Bushnell is your best bet.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
May 17, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I HAVE A RIFLESCOPE THAT THE RETICLE MOVED IN AND WAS NO LONGER STRAIGHT UP AND HORIZONTAL-NOW IT SEEMS TO BE CLOSE TO WHER IT SHOULD BE AGAIN-TRYING TO FIGURE OUT WHAT IS HAPPENING
Although I suppose it isn't impossible for the reticle to loosen, has the body of the scope perhaps just turned? Maybe the mounts need to be a little tighter.
Feb 02, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
3-9x40 bushnell scope red dot wont come on???
I believe your model takes an 3V lithium battery type 2032. Grasp the battery cover and turn it counter clockwise until battery is exposed small screw driver, gently pry the battery free, replace it and, tighten the battery cover.
here is a manual
http://www.bushnell.com/manuals/riflescopes/Banner_Riflescope.pdf
download it an keep it for your records
should it still not function To make contact on your scope
Bushnel Performance Optics
8500 marshall drive
lenexa, kansas 66214
Dec 12, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I have a Busnell Scope 3-9x40 73-3940S
If the reticle doesn't move at all, you've got a damaged scope. Don't bother to take it to anyone to repair, just send it in to Bushnell and have them repair it. Hope this helps, Mark the Gunsmith
Contact info below: United States
9200 Cody
Canada
Bushnell Corporation of Canada
25A East Pearce St.
Richmond Hill, Ontario L4B 2M9
Local Phone - (905) 771-2980
Other - (800) 361-5702
Local Fax - (905) 771-2984
Other Fax - (800) 661-3254
Dec 09, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Hello have lost one of my caps of my bushell elite 3200 scope woundering if I could get a new one thank you slade
i would try all the gun shops first they often have bits and bobs kicking about off old scopes its that or a placitck cap off some thing that will fit it,
Nov 10, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
How do I sight in my Bushnell banner scope?
Here is a great site for this issue:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Oct 10, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
NEED REPLACEMENT PART FOR TASCO 4X15 I NEED THE CROSSHAIR PIECE
im sorry but the price of that scope is not worth getting new crosshairs, you should just go get a new scope at walmart. they are like 9 bucks. But i myself would get a better scope, you can get decent ones for liek 60 bucks. Last a lifetime if you take care of them. The best scopes can cost 800 dollars on up. Just get a new scope. the part would coast more then the scope.
Dec 13, 2008 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Logo
99 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Andrew Taylor
Andrew Taylor
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
