Question about Airlink (AWLC3025) Wireless Adapter
Airlink adapter and att router access problems
Hello sir,
I am using a wireless network adapter airlink 101 wireless 11N mini USB Adapter. I have connected it to my pc which does not have a inbuilt wireless card. I have AT&T router and my service provider is ATT. I have been experiencing problems and when i access wireless through my PC as my network gets turned off temporarily and reconnects after a 30 sec- 1 min pause . When i browse i get a page saying network failure. This is causing me problems especially writing emails as i have to redo it from the beginning . I donot get this problem when i use a LAN cable to access internet through my PC. My PC is windows 7 64 bit home premium OS.
Please let me what is causing problems is it my router or my wireless network adapter.
Thanks
SAM
  • 6,826 Answers
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
Posted on Jul 04, 2010
Linux driver / cheapset / firmware
Which version and kernel of Linux are you running? That does make a difference. Post back with more info, please.
Sep 17, 2013 | Airlink 101 AWLL5088 Wireless N 150 Ultra...
The Airlink AWLC5025 Wireless-G cardbus Adapter doesn't find any wireless networks from a dlink router-n.
This could be a problem with the router not transmitting the SSID or the air card not detecting the signal being transmitted by the router. Check that your router actually supports the G format. If it does check that the router is transmitting the SSID, Your network name, on any channel except 6 or 10 if that is an option. Finally, test the Air Card with a different router, If it is not working with a different router it could be the Air Card that is faulty.
Jun 18, 2010 | Airlink MIMO XR AWLC5025 Wireless Adapter
Belkin wireless adapter trying to connect to Airlink 101 router
Did you type in the wep key and confirm it?It will not work is you type it in once only.
Nov 12, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
My Wireless connection status page is blank. Same with the wireless connection properties page and the "view available networks page"(or wireless network connection page) can't open, all it has is the top...
The AWL number was what I was looking for, thanx.
If the AirLink utility is running, there is where you would check the status. The way to set it so that the connection shows in the 'network connections '
Go into your Control Panel, then go into Network Connections
Right click on your AirLink wireless adapter and click “Properties”
Click on the “Wireless Networks” tab
Put a check in the box next to “Use Windows to configure my wireless network settings”
Click “OK”
If you wish to go back to using the AirLink101 802.11g Cardbus Utility, go back into the “Wireless Networks” tab in your AirLink adapter’s properties and remove the check mark next to “Use Windows to configure my wireless network settings”
Aug 03, 2009 | Computers & Internet
Can i use Bluetooth USB Adapter to connect PC to wireless router?
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
Aug 03, 2009 | Linksys (USBBT100-CA) Bluetooth Wireless...
Have an airlink card bus
If you have access to change the wireless routers channel do that. Log onto your router from the wired connection probably 192.168.x.1 (x is your subnet, find this by going to run>type cmd>hit enter>type ipconfig>hit enter the gateway IP should be your router
type that ip in a browser i.e. http://192.168.x.1 and log in go to wireless settings and find the channel option. usually you'll want to keep it at 1,6, or 11
(if your wireless utility doesn't show channels) go to your wireless pc and install netstumbler > install it > click the scan button and you should see all of access points around you. choose a channel that is used the least between 1, 6 and 11 and save that as your new channel on the router, as you are probably getting a lot of interference.
second try using the built in windows utility instead of the airlink one
also
update network drivers
update router firmware
don't sit around large metal objects :)
Jun 10, 2009 | Airlink (AWLH4130) 802.11g/b Wireless...
Atheros 5001 Mini pci lan adapter
If it is a LAN adapter, It is not a router.
A router enables you to connect several computers(256) with DHCP IPs
Sep 21, 2008 | Toshiba Satellite M35X-S109 Notebook
Access Internet using wireless USB adapter
from the pc that can access the internet
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Apr 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Unable to access the network
There are two things you can try, one is renaming the SSID in the Wireless settings from the default (WLAN) to another name then release and re-new the IP addresses. If that does not appear to work try uninstalling the Wireless USB network adapter(s), reboot and reinstall and that should solve the problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Airlink (AWLC3025) Wireless Adapter Logo
188 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
