Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
Pool heater comes on for about 15 seconds and then kicks off. A minute later it will do the same thing. Already replace hot surface ignitor probably because of over use. What ca the problem be?
I run into similar problem. Generally means filter is dirty. Run filter on RINSE or BACKWASH for a few seconds then try again. I am sure this is the cause.
Posted on Jul 26, 2010
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
How to replace Hot Surface Ignitor on Jandy LX 400 L
Be very careful, that is not a homeowner repair. If your heater is a Lo Nox 400 yes the burner comes out, you will probably find the wires are burned and there are other problems causing ignitor failure.
The standard lx400 the ignitor is reachable from the front.
Apr 24, 2014 | Pool & Spa
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
Master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have the same exact problem with this unit. Obviously getting gas to the unit, because it runs and pumps out some serious heat for a short time, but then kicks off. Did anyone ever figure this out or did you buy a new heater? :-)
Feb 25, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
We have a laars lite 2, when we openned the pool
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Furnace will not come on but thermostat is showing information
turn off power to furnace and open the front panel and see if you can see burners and gas valve and Hot surface ignitor.
If you can. turn furnace on and watch to see if the ignitor glows.
Let me know what you find. If it doesn't glow you probably have a faulty Hot surface ignitor.
If I had make and model number I should be able to find the part
Nov 16, 2008 | Honeywell Electronic Programmable...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
154 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
