Question about Frigidaire FEQ332E Electric Dryer
Frigidaire dryer wont run took the top off and will run if you gi
Took the top off and will run if you give it a push
  • 262 Answers
Your start winding on your motor are bad and you will need a new motor
Posted on Jul 04, 2010
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer timer runs but the dryer wont start
hi sarah take top off press start button and give drum a push clockwise if it goes then its the motor capacitor it will only go untill it stops to go outherway if goes change cap
Feb 14, 2014 | Dryers
The pump stoped running I took the pump off and pluged it in a power cord and it runs
Mine did same thing I took pump apart and found that the impeller was stripped out replaced pump works fine now.
Aug 11, 2013 | Frigidaire FEX831CS Top Load Stacked...
Hi. when i push the start botton it clicks but wont run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 23, 2011 | Frigidaire FER341ZAS Electric Dryer
Model # lde7304ace dryer, will not not go after pushing start, heater coil seems to be working and the "on" light goes on after pushing start but will not start
belt is broken:
belt diagrams:
http://www.fixya.com/uploads/images/7655D7D.gi
opening a dryer:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 13, 2011 | Dryers
I'm trying to remove the top of a frigidaire gallery dryer but it won't come off. I removed the two rear screws but the top does not slide back.
fistr make sure you took the right screws out,, on some of them the screws is the ones under the lip of the lid,, if you have got the right ones,, take your palms and at the front on the sides of the lid,, do a swift hard hit pushing back at the same time
Jan 21, 2011 | Dryers
My frigidaire dryer model NMER336FSO just out of the blue quit working. When I hit the start button i can hear a loan buzz, but it wont turn on.
It sounds like your Frigidaire may have one or more problems. If your push to start switch is defective then it will have to be replaced. You can test the switch itself by FIRST disconnecting power. Then taking the switch out and setting a voltmeter to test for continuity, then pushing the start button to see if there is on and off contact being made. Part number for the start switch is 131469000. If this is okay and you are hearing a buzz or low grumble noise coming from the motor area. this could indicate a bad motor winding and would probably have to be replaced. part number for the motor is 131560100. Sometimes however the motor can become seized or dirty connections to the motor can occur due to debris or dust bunnies. so make sure the dryer is CLEAN. If you give the drum a turn yourself manually, while trying to start the dryer this can sometimes give the motor the kick it needs. however this is only a quick fix, and not permanent. You have a well built simple dryer, and there isn't a whole lot that can go wrong with it. Hope this helps
Thnaks.
Nov 05, 2009 | Frigidaire Dryers
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
