Question about Bissell SpotBot Robotic Wet/Dry Vacuum
I used one tank of water/solution and the spot bot worked great. i refilled it and tryed to use it again, but all of the lights came on and it started beeping. why is this? is it getting too hot?
My machine is not spraying water. What can I do
Posted on Sep 04, 2011
I have the same problem. except mine is not new. How do I fix it?
Posted on Jul 11, 2010
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Clogged spot bot
There is a very small, white water filter (approx. 3/8" in diameter/ 1/8" thick) inside the "seat" where the solution tank connects to the machine itself. Could very well be your problem if you are in a city environment, or any other situation where hard water is present. This is a very easy fix; discovered it when my wife experienced the exact same problem.
1) Make sure other causes have been eliminated, such as clogged nozzles, etc. (Refer to owners manual.)
2) Ensure that the solution tank is indeed seating properly with the machine, (a few small bubbles rise from the connection once made.)
3) Remove solution tank. With needle nose pliers or a very small screwdriver, GENTLY remove the white filter from the black, movable "seat" connection on the machine.
4) Run the machine on manual (without the filter) to determine if this is indeed your problem. (Don't run for an extended period of time this way if this actually is your problem. The filter is there for a reason!)
5) Simply wash the filter gently between thumb and fore-finger. Vinegar may be used, but simple tap water works as well. If clogged, you should feel grainy, hard water type scale/ lyme build-up when cleaning the filter.
6) Recycle the original filter or replace if necessary. (It would be very easy to make a new one without going through the hassle of dealing with OEM parts or Bissell. Just go to your local hardware store and they should be able to help you out with no problem.)
Voila! Spotbot works again.
Hope this helps!
Dec 16, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
No Suction
Possible Causes Remedies
Tank is full. Empty tank.
Dirty/Collection tank latch is not down. Push latch down, securely
into place.
Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
Usually there is a seal out of place, or a filter is clogged, so you lose suction.
Apr 30, 2008 | Vacuums
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spot bot
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Nov 25, 2007 | Vacuums
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
929 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
