Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
I need to repalce he front bearing.
How do you get the impeller off?
  • 52 Answers
Take the rear cap off in the center of the rear motor. You will find a nut there and use pliers to hold this nut cause it rotates with the impellar. put a bind on it and the impellar should unscrew right off the shaft.
The Pool Tech
Posted on Jul 14, 2010
I have a LG model no LD-2040WH dishwasher that is troublesome at the moment. During the washing cycle, it gives a very high pitched screeching noise. It has now displayed an error code E1. I have take
The problem could be the washer motor bearing. LG motors have the impeller unit coupled to the motor and the water seal between the motor and impeller is a problem. The drop of water that leaks ends up on the bearing and it eventually gives problems. This can be seen by close inspection of the front bearing for slight rust indications .They use poor quality bearings but replacing the bearing is easy BUT you need to replace the water seal as this is the cause of the problem. Unfortunately the water seal is part of the plastic impeller unit and must be replaced. Not necessary to replace the whole motor as the bearing is easily replace and cheap. (the noise made by this fault is more of a slightly high pitch grinding / whine)
Jan 18, 2015 | LG Dishwashers
What is causing a whistling sound when the lg dish washer is in wash or rinse cycle but not when emptying wash or rinse water?
This does sound like the problem caused by the washer motor front bearing. The sound is more a whining sound. The bearing is of poor china quality and does start giving problems due to the water seal of the impeller that has the smallest water leak. The drop of water ends up on the front motor bearing causing the bearing to eventually pack up. You need to replace the water seal that is in the plastic impeller housing. Also replace the front motor bearing and this bearing is relatively cheap. Not necessary to replace the complete motor and impeller housing. Just the bearing (number 608) and the water seal (impeller housing includes seal)
Oct 09, 2014 | LG Dishwashers
How do I replace bearings in a swimmingpool pump motor
If you have a 1 hp motor or more they have 2 bearings, one at each end. It's better to do this on a work bench if possible. Disconnect electric from motor or electric box. If pump is bolted in two haves disconnect from the front have. That will leave you with the motor connected to have of the pump and the impeller. The impeller is threaded on and comes off clockwise. There might be a slot in the motor shaft at the back to put a screw driver in to hold it. After the impeller is removed there is a 2 piece seal that should be replaced when the pump is off. Remove the 4 long bolts from the back side of the motor to remove the pump and now the motor can be separated to remove the bearings. A bearing puller is needed for that then install new bearings using a pipe and hammer plastic is better. Hammer bearing on using a pipe that justs fits over the shaft. don't hammer bearing on it's edge. If you can clean the contact points in the back of the motor with some supper fine sand paper. Then reassemble . PS Some hardware stores might carry these bearings for about $12
Oct 01, 2014 | Pool & Spa
Motor very hard to turn. Bearing at end with power cord turns freely. Bearing against the pump hardly turns. How do you remove the pump and get to the bearing to replace? Should the pump be replaces as...
Vern,
to answer the question "should the pump be replaced as well?)
there are a few things that can answer that question for us. What is the condition of the existing pump? How old is it? Can the impeller even be removed from the shaft without breaking it?
Basically to change the motor bearings you must remove the 10-16 screws on the wet end.
Remove the cap you just unscrewed.
remove the small 1" round shaft cap at the rear of the MOTOR. (on the electrical end) this should come out with just a flathead screwdriver. (if it bends a little its no big deal.)
Lock onto the shaft end we just uncovered with a LARGE flathead screwdriver.
While locked onto the shaft, turn the impeller counterclockwise until removed.
Note: some impellers have a set screw in the center of the impeller.If you have one, it is reverse thread and must be removed by turning clockwise.)
If you are unable to get the impeller off of the shaft, you might as well buy a whole new pump. These pumps are a few hundred dollars, but if you have to purchase a new motor, a new impeller, and a new shaft seal at the very least, then the cost is right up there with a new pump.
If you can remove the impeller, keep reading.
Next remove the (4) - 1/4" hex through bolts located on the motor at the electrical end.
With the impeller removed and the through bolts removed, the wet end should now seperate from the motor.
To remove the bearings, we must seperate the front faceplate from the motor housing by taking a large flathead screwdriver to the small flat notch in between the plate and the motor housing. Pry in small even incriments all the way around the plate to remove this safely.
Once this is done, the bearing can be removed. For this we need a good quality bearing puller (these can be expensive and if you dont own one this is another reason to buy a new pump.)
Lock the 2 arms of the bearing puller around the outside of the bearing, and lock the center pin on the shaft and turn clockwise to remove.
When installing the new bearing, use a piece of 3/4" metal electrical conduit about 6-8 inches inlegth.
Place the bearing on the shaft and fit the electrical conduit on top of it, making sure to only apply pressure to the RACE of the bearing (the inside track) tap lightly until the new bearing is in place.
Once this is done, reverse these instructions to reassemble.
Dec 05, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
My Lg Diswasher is making a dry whinning noise all the way through while motor is running How can i tell if its the motor or the impeller Kim
The problem is indeed in the wash motor bearing.
unfortunately most motors come with complete with impeller.
You didnt mention model number so unfortunately i cannot give you a re[placement cost.
Regards
aardvark Repairs
aardvark.repairs@btinternet.com
Nov 17, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
I just repaice front end wheel bearings, when I
try replacong the sway bar bushings
Jul 12, 2009 | 1996 Toyota RAV4
Repalce cv joints
you need to jack the front end up and see if the wheels will move like the front wheel bearings are gone i bet you that will have to replace them your mustang is rear wheel drive there for you should not have cv joints in the front bushings and bearings
Jun 27, 2009 | 2004 Ford Mustang
Need to remove and replace front wheel bearings 1984 venture
dear 84 yamaha first thing i would do is to jack the front end of the bic off the ground and spin the front wheel and look to see if things look true . also listen for any slight noise coming from the wheel bearing. it is likely a bad front tire jim
Mar 30, 2009 | 1984 Yamaha XS 400 L Maxim
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
89 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
