Question about Euro-Pro Steam Generator EP8001 Iron
Euro-pro iron steam genarator model # ep8001
How can I order a steam rocker switch for this iron? Euro-pro says the won't ship directly to me.
  • Anonymous Mar 25, 2014
    Manual
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
Posted on May 20, 2008
  • Michael Earle
    Michael Earle Mar 11, 2012
    TAMPER BIT T-20 .. probably get them at auto zone ,not that expensive,then take the needed T-20 bit and cut a slot on the top end so you can use a common tip screw driver to place into the slot .. just drop bit into hole then stick screw driver in and line up slot .. presto changeo .. screw comes out . just repeat sequence in reverse when putting it together..good luck
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro ep8001 steam iron
I found the fix myself.
I found a switch without the light and it works
Sep 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro Pro Steam Generator EP8001 Iron - manual needed
Contacted Shark customer service and they emailed one. My product was the EP 8000 which is no longer produced. Sent the revised manual that is only a bit different for the EP 8001. Call them, they are very nice.
Jun 19, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
154 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
