Question about Frigidaire FAC126P1 wall/window Air Conditioner
AC Doesn't Power Up - Frigidaire FAC126P1 wall/window Air Conditioner
This model should have a test and reset button right on the plug. Hit test, and then Reset. Try this for starters.
Posted on Jul 09, 2010
  • 29 Answers
Check for power at the receptacle.
Posted on Jul 06, 2010
I have a 95 chevy cheyenne. My ac pump doesn't
Have you checked to see if the system has enough freon ?
If the system is low or empty the low pressure switch will prevent power from going to the compressor clutch.
Aug 29, 2013 | Cars & Trucks
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Apr 17, 2012 | Acer Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Laptop can't power on without battery. but plugged in
Try this. With the battery removed.
  • Plug in the AC.
  • Will pressing the power button repeatedly gently wiggle the AC adapter
If it powers on briefly then your DC jack inside the computer will need to be replaced or re-soldered.
If if doesn't power on at all get or borrow a multi-meter and set it for 20+V. With the AC adapter plugged into the wall and unplugged from the PC touch one probe to the outer metal on the part that plugs into the laptop and one probe down the center of the plug. If the probe doesn't go in all the way stick a paper clip down the center (dont let it touch the outer metal) and touch the probe to that. Ignore if the voltage reading is negative or not this just means the probes are reversed and doesn't matter really if you get a reading +-1 volt from what is listed on the AC brick. If you get nothing or it is very low then the AC adapter needs to be replaced.
If the AC is fine. Then it could be the fuse on the motherboard. In that event easiest route would be to replace the motherboard (don't think you can buy the fuses)
Comment back if you need more assistance.
Sep 08, 2011 | Acer Aspire One AOD150-1920 Netbook
Doesn't turn on only acts like it is but screen doesn't turn on.
solutio
step 1: test A.C. power cord
step 2 : test your A.C. transformer
step 3 : test your fly back transformer
step 4 : Test your ON/OFF volume switch
step 5 : Test video I.C. and more test were test by the A.V.O. miter
Send report :babul_jpi90@yahoo.com
Thank you .
plese send me only one vote
Jul 28, 2011 | Televison & Video
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
Frigidaire FAC126P1 wall/window Air Conditioner Logo
144 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
