Question about ION Audio TTUSB10 Turntable
No sound thru computer - ION Audio TTUSB10 Turntable
I have the same problem. I unplug the USB hat goes into the computer then I have sound. I'm trying to find out why I have to disconnect the cable.
Posted on Jul 06, 2010
Lock unlock beep sound
After dead battery, readouts
including gas used do not read normally. These "learned" results have to be relearned by the computer-----this will
take driving 100 miles or so. You would only do that if it starts and runs with normal sounding engine performance= if it does not start/run sounding normal, diagnose and fix your other problems, not just the computer memory.
The scanning for codes will not help until the computer "remembers" something----which does not happen with a completely dead battery---memory is erased. I am writing this for Ali Fardshisheh on Apr 20,2014. (There are many other "learned" data elements in the car computer that will not be accurate until
you drive about one hundred miles, so the computer can relearn them thru a NUMBER of normal operating cycles.....IF IT DOES NOT START AND SOUND NORMAL, you cannot apply this solution.)
BEEN THERE, DONE THAT! Just as an example, when I
went thru the 'really dead battery' cycle, the gas used was not
displayed when I got back to running. After I drove thru many
apparently normal miles, the mpg crept up very SLOWLY, from
1, 2, 5mpg, until it eventually plateau-ed at its usual between 15 and 20mpg. I assume there are many other 'learned' readouts that would behave in the same way------this was the only readout I was following as I was not interested in the others, but I presume numerous others are operating in a default mode thru many driving cycles until a memory data-base builds up.
Now I have to go see my DeVille mechanic. I will try to check later and see if you have a response. I have a good mechanic, if you need one. Best wishes....
Apr 19, 2014 | 2006 Cadillac BLS 1.9
Can't get sound thru my stereo and stereo speakers
If it is just the sound from the computer then if you have windows look for the little speaker icon in the bottom right corner of the screen, right click this, select "Sounds" then select playback (while connected to the tv) and chose the tv as the output device (set to default).
If on the other hand the issue is with the tv at all times then try going into the menu settings of the tv and looking for the various sound options. Possibly the remote control will have an audio button that scrolls through various audio options (two circles followed by roman numerals?).
Hope this is of some help.
Nov 22, 2013 | Televison & Video
No audio. no manual.
how is ur sound output from the computer box is conencted....is there an external speaker thru which u listen sound ?
if so that cable from the sound output slot on the PC need to shift to the monitor speakers thru some cable that goes into the monitor from the CPU box....
Jan 04, 2010 | Computers & Internet
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
My computer have no sound
look in your sounds options and see if it is checked digetal only.If it is then uncheck that box and try again.
Sep 21, 2008 | Computers & Internet
I need to hook up this system to my tv.... thanks
you want to install your TV sound thru this Surround sound system ?? let me know
Apr 22, 2008 | Logitech Z-5300e Surround Sound System...
ION Audio TTUSB10 Turntable Logo
102 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
