Question about Panasonic Lumix DMC-FZ8 Digital Camera
Mark on screen and photos
There is a dark blob on the screen and the same on any and all photos. The outside of the lens is clean. Can this be fixed as it appears to be inside the camera.
Thanks.
    President:
  • 2,702 Answers
This is a fault with the ccd this is deep inside the camera if it has dust on it you may get a cheep fix done if not its going to be pricy?
Posted on Jul 04, 2010
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
Bubbles are projected on the screen
I am assuming that the "bubbles" are most prominant when the picture is dark. If that is the case, it is most commonly referred to as dust "blobs". Dust particles get on the lens assembly inside the projector and are just out of focus so they appear as blobs or bubbles. If you can carefully remove the cover and gently blow out the lens / color wheel area with compressed air it should reduce the "bubble" effect. I would not recomend any further dissasembly as it is complex and time consuming and unless your very careful, could end in disaster. Don't forget to clean the air filters either.
Aug 03, 2011 | Optoma EP721 Projector
I have a Hitachi CP-S240 projector. It works fine but now projects a yellow blob on the screen. It looks as if someone took a highlighter and colored on the lens - I cleaned the lens and that is not the...
I work for a company where we take care of around 7,000 projectors. We have recently come across this same issue in this model and several other Hitachi models. We have figured out that it seems to be a main board issue, after testing and checking of the lenses and other things. The main board ended up being the fix. Hope this helps!
Apr 12, 2011 | Computers & Internet
Sir i have purchased nikon p100 camera from croma stores belapur branch , the problem with the barrel and there were gear noise and on taking photos in dark back ground of moon there were several white...
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
Mar 15, 2017 | Nikon Cameras
Tiny black dots and a hairline mark now appear on all my photos using a Nikon D40
You might have to have your sensor cleaned. When the camera body is exposed to excessive amount of dust they can get in the mirror housing. When the shutter opens and the mirror flips out the way when a photo is taken, it aggitates the dust then it falls on the sensor. It will need to professionally cleaned by a repair technician.
To test it is dust, take a few photos of a white wall at aperture f22 with the flash on and if they are all consistant that is problem. They will look like soft black blobs.
Oct 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Vp800 LCD Projector has dark blob on display.
blow out any dust with canned air. chances are there is an object blocking the image. or there is a crack or burn spot on the 2nd fly-eye lens (diffuser). the first one is right next to the lamp (if you remove the lamp, you'll see it). the second is right on the other side of it.
Jul 14, 2009 | Office Equipment & Supplies
Dark circular spot on Ricoh R6 screen and images
There is a spec of dirt that made it inside the camera and has landed itself on your image sensor.
If you take a picture and the image has a spot on it, it could be the screen. If you transfer it to your computer and the spot is in the same spot, its something on the image sensor. You would have to send it out for cleaning, and a new camera would be cheaper.
Mar 30, 2009 | Ricoh Caplio R6 Digital Camera
Blob on photos
Sounds like you have your "blob" on the actual CCD sensor in the camera. There are special "cleaning kits" to remove dust etc. from the sensors without damaging them. I would not suggest trying a "home-brewed" system of cotton swabs, isoporpyl alcohol, and a can of compressed air, unless you were very well versed in this operation. A scratch on the sensor will ruin the camera. Have a qualified shop do it, or buy the sensor cleaner kit, if you want to be safe.
Feb 22, 2009 | Nikon D70s Digital Camera
Dark piece on screen using JVC DLA-SX21
Can any1 help me with this problem...i have a purple blob in centre of projection screen.
is this a burn mark on the lens..maybe due to over use?
Any input would be great!
Aug 20, 2007 | JVC DLA-SX21 Multimedia Projector
Panasonic Lumix DMC-FZ8 Digital Camera Logo
208 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
