Question about Dryers
I have a clothes dryer (Alliance) that I'm trying to fix. It's electric and it operates with coins. When coins are put in, the door has to be closed and a button has to be pressed for it to work. However, when it should start, it sounds like energy is reaching it but the motor doesn't start.
    President:
  • 1,554 Answers
The issue is with the thermal fuse mounted on the blower housing alongside with a cycling thermostat. The thermal fuse is wired in series with the motor circuit, making the motor not run when it fails. Bypass the thermal fuse and if the dryer runs, it is definitely blown and must be replaced. Otherwise, the issue is either in the timer, start button, or the motor itself.
The cycling the thermostat must also be replaced when replacing a blown thermal fuse. It is due to the fact that a blown thermal fuse is a sign of a failed cycling thermostat. It fails to cycle the heater properly which leads to the blowing of the thermal fuse.
Indicate the make and the exact model number of the dryer should you need further assistance. You don't have to accept, reject, or rate this post in order to add information or post follow-up questions. You can post and communicate me as long as you need assistance with regard to the issue stated herein.
Posted on Jul 04, 2010
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
Why are there coins in my dryer lint trap?
when a person has coins in their pockets & forget to take them out,when the clothing is wash sometimes the coins don't get washed out,, but when you put the clothing in the dryer the tumbling will help the coins come out of the pockets that when they go to the dryer lint trap or bottom of dryer
Aug 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer started, ran 10 minutes stopped.
Check the thermal fuse for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 5.7 cu. ft. Coin Operated Electric...
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
My Coin-operated Maytag cdryer does not dry clothes
One of the elements is bad OR one of the breakers may be tripped. Check the connections in the back of the dryer.
Jan 04, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Dryers Logo
32 people viewed this question
Top Dryers Experts
