Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon mp210 problems
My canon mp210 says that there is no paper in it but it has paper ready
  • telezc09 Aug 19, 2008
    Yes same here. My printer says that the printer is out of paper even though there is paper in it and prompts me to lolad it and press start. When I do press start it still doesn't print. This printer is literally new, I have printed one single document on it and it's acting retarted.
Paper pulling to one side no paper message.
Mine turned out to be a blockage I couldn't see. In an attempt to clear any obstructions I shoved a library card where the paper enters through the feeders till I could see it come out inside ( where you lift up the scanner for ink maintenance.) I went across its length re-inserting the card and then felt resistance. I carefully pushed and out came a little piece of stupid plastic.It works now .Sigh,.. The printer is set under a windowcill where it came from . I may also warn If you put stuff on top the scanner lid makes a great slide for sending them to them paper feeder .
Posted on Feb 27, 2009
  • stukonu Jan 17, 2011
    Thank You so Much this worked awesome. We had bunch of hidden junk stuck in there the library card worked great. I was just about to give up and go get another printer. Thanks again!!!
I had this problem for a while before I decided to take the printer apart... there wasn't any obvious obstructions that I could actually see, so I put it all back together (fyi...don't bother trying this)
Then I came here.
Haupia's suggestion solved it for me. Instead of a library card, I used an old expired credit card, through the paper slider/roller back and forth (or in and out) along the length, just as described... Sure enough, a crumpled-up cigarrette wrapper foil popped out.
It's working great now...
Thanks Haupia!!
Posted on Mar 31, 2009
  • Diane Lynch Dec 29, 2010
    I M SO grateful for the credit card suggestion - after doing all the ¨looking¨and other steps, using the credid card which had more power than paper, my son found the problem - he actually paid attention to my inquiry suggestion - He found a cherry pit, contribution of my 5 year old granddaughter. Many many thanks from the Chile contingent user. Diane
I solved this....yeah!!i came on here for a solution and gave up. fiddled with my printer and it worked.heres what i did in case it can help anyone eles out.keep in mind im not a professional so i dont know if i am going to make your printer worse or not.
first i unpluged my printer.i took out all the paper and waited for like 5 mins.i then looked in side and saw that to the right on the bottom of the printer there was a little metal thing sticking up that was blocking the way of the ink canasters from moving...and possibly the paper from going threw.i pushed that down. and blew out some dust.i then blew in the area that the paper goes to make shure nothing was there.i pluged in the printer and put the paper in and pushed the power on.and there was no error flashing.printed out a sheet and it went right threw.
i hope this helps someone.and hope that i dont damage anyones printer worse by giving this out.but gooood luckkkkk........
Posted on Jan 17, 2009
  • jmc4847 Feb 06, 2011
    I found a small 'thumb tack' had fallen into the back of mine. I turned the printer upside down, gave it a shake
Thank you ilovejosh! I am back in business, whew!
Posted on Feb 20, 2009
Just smother your steak with barbeque sauce and dont forget to preheat your grill
Posted on Nov 07, 2008
Have you tried the basic trouble shooting tasks, like powering off you printer, removing the paper, powering back on and replacing the paper? Your paper also may not be down far enough into the paper slot to nudge teh sensor, meaning that though the papers there, the printer doesn't think it is.
Posted on Aug 28, 2008
Buy Another Printer Or Purchase a LEXMARK 1995 - X Series 2 888
Hope this helps!
Posted on Apr 22, 2008
Printer keeps saying E3 after paper jam, I already removed paper but E3 won't go away and I can't print. How do I solve this problem and get the printer to print again?
Hello!
Here is your solution. 1. Press reset/stop button for 5 seconds without releasing button. 2. After 5 seconds your printer will start one process..release the button. 3. Now your printer is ready to use..... thanks
Sep 12, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 pulls paper to the right.
Hello
So your printer has a paper skew problem? first of all was there any paper jam in the printer earlier?
Jul 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My Canon MP210 is not sending paper through when trying to print. The roller doesn't seem to be able to grip the paper properly
Precisely. On many printers that get older, the rollers shrink and don't grip paper properly. I had this problem on a laserprinter made by HP, that would take 5 sheets at a time due to this problem.
Feb 12, 2011 | Canon PIXMA MP210 InkJet Printer
What is error code 2 on a canon MP210?
This steps may solve your problem.
1.Load paper correctly then press black or color button (MP210)
2. Press on/off switch to reset the multifunction device
3. Remove Packing Material MP210
4. Reset ink cartridge MP210
5. The MP210 may require repair
If your printer is new , make sure the packing material inside the printer has been removed. You should have a quick setup page and/or users manual that will show you how to remove any packing material that is inside the printer.
If this is an older printer that has worked in the past, start with step
1, 2 and 4. If this does not work contact the Canon customer s
Dec 13, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do i print in colour with my canon mp210?
Hiya,
I have found the user guide that will helpyou with this particular problem, and any other issue relating to this piece of hardware. The download link for the manual is listed below. Copy the link into your browser address bar and you are all ready to read up on your cannon pixma mp210.
I hope this is the fixya for you.
Any problem? give me thhe details and I will resolve it ASAP for you.
Yours sincerely
Oz
Feb 25, 2010 | Canon PIXMA MP210 InkJet Printer
Canon MP210 printer won't print
Hello
Thank you for using
FixYa for your problem
Need some more info on the issure.
  • Is the printer light showing ready
  • Is on your computer in the printers folder the printer icon showing ready
  • is there paper
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Canon PIXMA® MP210 Printer
I need help with my canon PIXMA MP210 printer, the printer keep jamming paper
try to check if there is small particles or small papers that lock inside the printer.. maybe something is blocking the paper
Aug 25, 2009 | Canon PIXMA® MP210 Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
631 people viewed this question
old marine
old marine
