Question about Refrigerators
The temperature in the fridge is too high and even though we adjust the temperature it won't come down
    President:
  • 2,702 Answers
This is becouse the thermostat has stoped working and is jamed on ,,,change the thermostat for a new one
Posted on Jul 04, 2010
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Refrigerator temperature running too high
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 03, 2009 | Whirlpool ED2FHEXN Side by Side...
My RM2852 Is Freezing the food in frige section, what might the problem, be? Does this unit have a defrost switch??
Located in the inside in the rear top of the fridge are aluminum fins. on one of the fins near side of fridge there is a folded aluminum sleve that skides up and down on the fin.
this actualy adjusts the temperature of your fridge. slide up or down to adjust fridge cabnit temperature.
Aug 28, 2009 | Dometic RM2852 Refrigerator
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Zanussi ZNB 3450S Fridge Freezer not cold enough
it is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last year.it should still be under waranty
Feb 27, 2008 | Refrigerators
Fridge temp too high
probable cause is jammed fan. first take back panel off fridge, electrical connections are plug and socket. yoy may find a quite small build up of ice underneath the fan. melt it off and you should be ok. samsung are prone to this problem
May 08, 2007 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
