Question about Maytag Neptune MDE5500AY Electric Dryer
Difficulty level? What has to come apart to get
Difficulty level? What has to come apart to get to the thermistor? Is it just a matter of taking the back off?
  • 262 Answers
To answere your question, you need to remove the front of the machine witch inclused the door and the thermistor is located near the blower housing.
you can see a breakdown of a simalar machine here
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=MDE5500AYQ&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&searchedModel=mde5500ay
There is also a thermofuse and Thermostat located on the heater tube you might want to make sure its ok and befor you do anything make sure you unplug the machine.
Good luck
Posted on Jul 04, 2010
There are four sets of wires that connect to different parts on the manifold of my Pentair Heater including the thermistor. Does it matter whether you hook them up left to right or right to left.
The individual 'pair'of wires that went to the sensors and thermistor, need to remain on that sensor, but it doesn't matter which wire goes where for that sensor.
so, to clarify... If you took a wire off of the low high limit, and ended up placing that wire on the thermistor, and a thermistor wire on the high limit, you may end up with a heater that will not fire.
May 21, 2015 | Pentair 460732 MasterTemp Heater 250BTU ...
How test a thermistor
Hi jorge
Hi
To test your thermistor you will need:
Soldering iron
Multimeter or ohmmeter
Follow the directions below to test your thermistor
1...Set the multimeter to resistance mode lowest setting.
2...Hook up the terminals of the multimeter to leads on the thermistor.
It does not matter which lead goes to the terminals, polarity is not important in this test.
3...Heat the soldering iron then heat the thermistor by moving your heated soldering iron tip to it.
Note: Check the multimeter reading as you are applying this heat.
A properly functioning positive temperature coefficient thermistor will show a smooth and steady increase in the multimeter
resistance reading.
A properly functioning negative temperature coefficient thermistor will show a smooth and steady decrease in the multimeter
resistance reading.
4...Look for other signs that the thermistor is faulty.
A steady reading that does not change, a reading of zero or a reading of infinity are all indications that the thermistor needs to
be replaced.
If the change in the readings is not smooth or if there is not any change, then this could also indicate a faulty thermistor.
Please take time to rate me.
Bud
Oct 31, 2012 | Dryers
What is stratatitle
Strata title is a form of ownership devised for multi-level apartment blocks and horizontal subdivisions with shared areas. The 'strata' part of the term refers to apartments being on different levels, or "strata".
Strata title was first introduced in 1961 in the state of New South Wales, Australia, to better cope with the legal ownership of apartment blocks. Previously, the only adequate method of dividing ownership was company title, which suffered from a number of defects, such as the difficulty of instituting mortgages. This term also applies to house-type strata title units in Australia.
Oct 30, 2012 | wikipedia.org
My washer keeps giving a unbalanced load no matter the size load and even when it don't seem load is unbalanced.
Perhaps the washer isn't sitting level? Use a carpenter's level on the top surface and make sure the machine is sitting level. Next screw down the feet as necessary to maintain a level washer. In some cases, the "solenoid" is out which is servicable by a repairman. Not an expensive fix by the way, but not easy for the uninitiated among us.
Oct 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
Tools req. and approx difficulty level(1-10)for brake check and change pads please on toyota previa 2.3 petrol 7 seater
to check the brakes you can look through the wheel to see the pad thickness(1/8th min)then run you finger over the disc(rotor)to make sure you don have to much of a lip around the edge.(1/32 max.)as rotors only last around 40k and pads around 30k, i would change both together,difficulty 3/10 for diy mech.tools req pliers/mole grips(to grip brake pipe)/tyre iron(to force pistons apart,take off filler cap first)phillips screwdriver to take out screw in rotor,and a hammer
to release rotor from rust on the back of it.a range of metric spanners/sockets.to remove caliper from bracket and copper grease for the back of the new pads(to stop them squeeking).
put together the opposite of taking them apart,keep all bits in hubcap on top of wheel(you never have bits left over if you do this...)and prise apart pistons before you take caliper off the car,then apply molegrip to rubber pipe so they dont close up.
Apr 24, 2010 | 1995 Toyota Previa
Richoh FT 3713
E55 Fuser thermistor open
replace thermistor located in fuser
Sep 26, 2008 | Ricoh FT3713 Copier
Maytag Neptune MDE5500AY Electric Dryer Logo
181 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
