Question about Little Giant VCMA-15ULST, 1/50 HP, 65 GPH - Automatic Condensate Removal Pu
Water is dripping rapidly from my VCMA 15ULS. Do I need to replace it? Or can it be fixed?
  • 760 Answers
I assume the unit is overflowing, because the pump is not running. Check th hose connection and be sure the line bringing the water into the pump is inserted in the opening. Can you hear the motor run? You can remove the top, and be sure the float switch is working and that the pump inlet is not clogged with debris. Sometimes you'll get mold and dirt mixed with water clogging the inlet. If the motor doesn't run, and the switch works, then it probably isn't worth fixing as you can buy these from 35.00--50.00
Posted on Jul 04, 2010
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Water is dripping from behind the glove box. The drip is slow when the heat is on, and very rapid when the A/C is on. I don't notice much of a drip as long as the heat or A/C is off.
Your heater core is most likely leaking or possibly the hose connecting to the firewall. Bad situation either way as it needs to come out for repair. Might need to remove glove box and associated plastic around the area to get at the heater core. Remove heater hose attached to firewall in engine compartment(2) Will drain water so be careful. To drive vehicle w/o using either heat or cool attach the two hoses you just removed by using a pipe that fits tightly inside them and a screw clamp on both hoses. this will get you by unitl you can fix the core.
Apr 20, 2013 | 2007 Chevrolet Chevrolet Cobalt LT
Little Giant 554455 VCMA-20ULS 230V 20' My pump runs when the float is down low in the tank and comes off when the float is high in the tank. So it runs continuous. Has something gone wrong and...
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
May 29, 2011 | Little Giant 554455 VCMA-20ULS 230V 20'
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
This is happening to me, too: Model # VCMA-15ULS condensate removal pump switch suddenly began working backwards - it will go on when the float is down and shut off when the float goes up. What is the...
The switch goes bad and that happens sometimes...
I guess you could change the switch but for the price of a new one it isn't worth my time... I junk em and throw a new one in...
heatman101
Sep 17, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Little Giant VCMA-15ULST, 1/50 HP, 65 GPH - Automatic Condensate Removal Pu Logo
1,014 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
