Question about Casio EXILIM EX-Z1000 Digital Camera
After transferring pics to my pc, when memory card is back in camera, it says no files are there. how do i retain pics on memory card to show on camera?
  • 6,826 Answers
Check for a setting in the software that deletes pictures fom the card when transferring pictures. Set it to another setting, if this is available.
Posted on Jul 04, 2010
How do I transfer pics from my pc back on to my fuji S5700 camera
You'll need to use a card reader. Once the memory card is in a card reader (either built-in to the computer or connected via USB), the card will appear to the computer as another external hard drive, and you can copy files to it the same way you usually copy files.
Be aware that if you've done any editing of the pics (opening a pic in a photo editor and then saving it without doing anything counts as editing), the camera most likely won't display it.
Feb 15, 2012 | Cameras
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
How do i get the pictures from my camera to the memory card
the question I ask is why would you want to do this?
The camera has XX Mb of memory in case the card becomes full. Generally one downloads the pics on to a PC and deletes the Camera files to start again
If you want to keep the pic files in memory and save them tpo your pc. remove the card for safety.. Interrogate your camera via the connection cord and the software it came with. Download the folder with the pics in memory to your PC. Then delete the files on the camera. Insert the SD card and In menu, set up to save files to SD card rather than memory while there is space.
Please rate my help++++Thanks fore using FIXYA
Apr 16, 2010 | Samsung L200 Digital Camera
Cpu won't read memory card
look beside the memory card on the side of it says "locked" slide the switch back to unlock it and you will be able to transfer the pics.
Feb 13, 2010 | Computers & Internet
Can't veiw pictures from memory card on camera
Some cameras do not allow a computer to camera transfer. It causes the card to have a different initialization not compatible with your camera. If the pictures are safely on your computer, format the card in the camera and it will be fine.
Nov 14, 2009 | Samsung S760 Digital Camera
Pictures not accessible on memory card
Nope. Ur memory card might have been formated by the camera with a different file system.
So use your camera to access your pics and to transfer to PC.
Feb 28, 2009 | Nikon Coolpix S210 Digital Camera
Memory card 'full'
if u have these pics on pc then
pls format ur mem card thru laptop card reader or a card reader elsewhere and then try taking pics it will not show the msg actually file system got corrupted
Jan 15, 2009 | Samsung Digimax L830 Digital Camera
Kodak Easyshare LS753,lost pictures during USB transfer to PC
You can recover photos from camera with asoftech photo recovery program. You can download the program from
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Nov 14, 2008 | Kodak EasyShare LS753 Digital Camera
File Transfer Error
Hi.
I recommend using a card reader available nearly everywhere.
Plug it into the PCs USB port. then it should show up as a drive. transfer the files and you're done. Don't forget to 'safely remove' the drive before unplugging it.
Ken.
Aug 02, 2008 | Canon PowerShot S3 IS Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
50 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
