Question about Nokia 5230 Cell Phone
My nokia fell in the water,and doesnt want to turn on?it turned on once then the screen turned into different colours,then i switched it off.Can you help me please
SOURCE: Nokia 6300 display problem - lines on screen
change ur lcd
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Posted on Apr 05, 2009
frithangelo
  • 21 Answers
SOURCE: Nokia 6300 on off switch problem
the switch button is or maybe broken
the best way is to send it right away to the nearest service center
Posted on Apr 27, 2009
freetek
  • 5568 Answers
SOURCE: e71 nokia fell in water..no signal..all ok otherwise
If your (bad) luck is holding, low-level circuits have been damaged by current from elsewhere, especially if trying to connect since this uses circuits capable of much higher power than the low-level ICs were intended to deal with.
Since it isn't working anyhow, try this:
Add a drop (not more) of dish detergent to a couple of quarts of warm distilled water - no product that has anything added to the water. Remove the battery from your phone, dunk it into the solution and swirl it a bit to ensure penetration of the solution.
Rinse it in distilled water only, shake out whatever you can without slamming against anything. Allow it to dry (battery compartment open) in any warm place such as a sunny railing, window sill, etc. for at least two days.
I have used this method successfully on a number of electronic items with good success.  The most extreme incident was a word processor I serviced (many moons ago) belonging to an author who had weeks of work stored in the unit when his tom-cat decided it was a good place to urinate.
Good luck-
Posted on May 23, 2009
Mr Biola
  • 496 Answers
SOURCE: my nokia 2730 is fell
YES , YOU WILL HAVE TO CHANGE THE DISPLAY SCREEN.
Posted on Jan 25, 2011
Two days back my cell nokia E7 fell into water and was there in it for 5 minutes.Intially it started after a while when we kept in sun n made it dry but later on it got switched off and till now its not...
First: Do this before:
Remove the battery and sim
Then DRY it with warm air (hair dryer) for 5 to 10 minuetes or more
but keep the dryer far of the phone in case it becomes too hot and be damaged.
keep do this till it turns on
IF it doesnt work, Find A MOBILE REPAIR STORE.
May 19, 2011 | Nokia E7 (16 GB) Smartphone
My g1 fell in water but not fully submerged in
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 05, 2009 | HTC G1 Smartphone
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 6080 Fell in water
It is stuffed, if it falls into water then the second it falls in it will short, and probably blow some critical components inside, even if the phone is off then there is always power running through it (so it knows when you are pressing the button to turn it on, also so it can remember the time and date)
May 24, 2009 | Nokia 6080 Cellular Phone
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
Nokia 1600 displaying local mode
this problem is because of water which is dried over some components inside ur phone. take it to technician, it need to be cleaned from inside with acetone, if problem still stays then it need to be repaired very minor.thanks.
Feb 24, 2008 | Nokia 6030 Cellular Phone
My fone fell into water
the same happened to me tooooo, it fell into the sink, and now only has light on the screen and nothing else, and goes off it self in a few moments, i tried USB'ing all data to PC, but PC is failling to recognise the device! even with PC suite!!!!
What shall i do?
Nov 04, 2007 | Sony Ericsson K800i Cellular Phone
Motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Oct 31, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 5230 Cell Phone Logo
147 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
