Question about Steamist System 18 2@9KW 240V 1PH - 1810-IM
New System 18 dual unit just installed and slave wont turn on.
New System 18 dual unit just installed and slave sm11 does not turn on with master sm11. (F=female, M=male)
Two controls, temperature inside and timer outside are connected together behind inside temperature unit with 6 wire 2F to 1M coupler folloed by a 1F to 1F coupler and then run with single 6 wire cable 25ft to the master steam generator unit where a 6 wire 2F to 1M coupler plugs in to the master. A sound cable 25ft connects to this 2F coupler and runs to the slave unit and connects to 1M jack on slave board. Master unit comes on with controls but slave is never seen to activate.
Both units function seperately if test button on control board is pushed. Slave is powered up and can function with test button only.
Is there a jumper to move or different wiring than is given?
Are the wires and 2F to 1M splitters and !M-1M all identical with full 6 wire straight through support?
Are there any tips of Help ? !
  • 905 Answers
Hiya!
You are almost certainly looking at a wiring problem with the interconnect cables. Check the continuity between pin to pin. You may find that some pins are reversed. This could be okay, or not. Verify with manufacturer.
Are you using standard ethernet cables that you bought, or were they supplied with the unit, or were they made by yourself as a custom fit?
Posted on Jul 07, 2010
  • Sheldon Dedek Jul 08, 2010
    My mistake, you had indicated 6 wire, not 8. But still, were these made custom, or did they come in the parts bag?
2003 Scenic 1.9DCI, new clutch, slave flywheel fitted 18 months ago after clutch failure. Last month pedal went flat to the floor and unable to put into gear. Bled system, car ok for a couple of days then...
There are only a few places air can get in the master cylinder and connections the pipe going to concentric slave the connections to slave or slave itself
Feb 05, 2015 | Cars & Trucks
2006 chevrolet cobalt clutch issues
Just because the master is new does not mean it isn't faulty. If you are certain you have bleed all the air from the system, I suspect you got a bad master.
Nov 21, 2012 | 2006 Chevrolet Cobalt
Drive runs but cant get into it
thankful to share to my idea.
j1.gif = jumpered
j2.gif = unjumpered
Master (J50) j50.gif Only drive in single-drive system, or master drive in dual-drive system Slave (J50) j4.gifSlave drive in dual-drive system Cable select (J48) j48.gif (default) Cable select
hope it can help to you my friend.
Aug 30, 2011 | Passport Essential (WDME2500TN) 250 GB USB...
I have a 1997 saturn sc2 im trying to bleed the clutch slave cylinder
In this car, there is no bleed port provided. The hydraulic clutch system is closed and is sold only as a complete set of master, reservoir, slave, and line. The set is priced at $130 at autozone.com. I have pasted the replacement instructions from autozone.com below. Please let me know if you have more questions.
See Figures 1, 2, 3 and 4
The master cylinder, pipes and slave cylinder are a complete assembly and must be replaced as a single unit.
  1. Block the clutch pedal to prevent it from being depressed while the slave cylinder is removed from the transaxle.
  2. Remove the air cleaner/intake duct assembly.
  3. Disconnect the negative battery cable first, then the positive cable.
  4. Remove the battery hold-down retainer.
  5. Remove the battery from the vehicle. Store the battery in a safe location, but do not place it on a concrete surface for any long period of time or it will discharge.
  6. Remove the battery tray. Note that one battery tray mounting fastener is only accessible through the fender well.
  7. Rotate the slave cylinder about 1 / 4 turn counterclockwise while pushing toward the bell housing, in order to disengage the connector and remove the cylinder from the clutch housing. Remove the slave cylinder bracket retaining nuts and pull the assembly from the studs.
  8. If equipped with ABS, remove the brake master cylinder-to-power booster mounting nuts. Move the master cylinder off of the mounting studs and slightly toward the engine, being careful not to bend or kink the brake lines.
  9. Remove the master cylinder pushrod retaining clip from the clutch pedal pin and disconnect the pushrod from the pedal.
  10. Rotate the clutch cylinder about 1 / 8 turn clockwise and remove it from the instrument panel. Remove the hydraulic assembly from the vehicle.
To install:
  1. Install the clutch master cylinder into the dashboard with the reservoir leaning toward the driver' fender. Rotate the cylinder about 1 / 8 turn counterclockwise to lock it in position.
When installing a new assembly, the plastic retainer straps should remain in place on the slave cylinder, to ensure that the actuator rod seats on the release fork pocket upon installation. If reinstalling an assembly, be sure to position a new plastic retainer strap onto the end of the pushrod and attach the straps to the cylinder.
  1. If equipped with ABS, place the brake master cylinder into position on the power booster mounting studs. Install and tighten the master cylinder-to-power booster mounting nuts to 20 ft. lbs. (27 Nm).
  2. Slide the slave cylinder onto the clutch housing studs, then install the nuts and tighten to 18 ft. lbs. (25 Nm).
  3. Insert the slave cylinder into the clutch housing with the hydraulic line facing down and rotate about 1 / 4 turn clockwise while pushing it into the housing.
  4. Lubricate the clutch pedal pin with silicone grease, then connect the pushrod to the clutch pedal and install the retaining clip.
  5. Install the battery tray. Tighten the battery tray mounting fasteners to 89 inch lbs. (10 Nm).
  6. Place the battery into the battery tray. Be careful that the battery terminals do not short against any metal during the installation.
  7. Install the battery hold-down retainer.
  8. Connect the positive battery cable first, then the negative cable.
  9. Install the air cleaner/intake duct assembly.
  10. Remove the block from behind the clutch pedal and, if equipped, properly enable the SIR system.
  11. Start the engine and check the pedal for proper operation.
Fig. Fig. 1: Block the clutch pedal to prevent slave cylinder damage, should the pedal be depressed while the cylinder is removed from the transaxle
999d0d2.gif Fig. Fig. 2: To remove, rotate the slave cylinder about 1/4 turn counterclockwise while pushing toward the bell housing
Fig. Fig. 3: This plastic retaining strap must remain on the slave cylinder to ensure proper seating of the actuator rod against the release fork
Fig. Fig. 4: Rotate the clutch master cylinder about 1/8 turn clockwise and remove it from the instrument panel
HYDRAULIC SYSTEM BLEEDING The clutch hydraulic assembly has been filled with fluid and bled of air at the factory. Do not attempt to bleed the hydraulic system. While the unit does not require periodic checking, it must be serviced, when necessary, as a complete assembly. The system is full when the reservoir is half full.
Only DOT 3 brake fluid should be added to the system. If the fluid level drops, inspect the system, including the slave cylinder, for leakage. A slight wetting of the slave cylinder surface is normal. Fill the clutch master cylinder reservoir with brake fluid. Be careful not to spill brake fluid on the painted surface of the vehicle.
Oct 31, 2010 | 1997 Saturn SL
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
What are the jumper settings for a maxtor 90640d4
this is layout " : : : . : " also no jumper for slave
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Oct 08, 2009 | Maxtor Hard Drive
Hard drive installation problem
Yes it is possible but you need to set it up as a dual boot system with XP installed on the 2nd drive (slave drive).
Mar 16, 2009 | HP Compaq nx6110 PC Laptop
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Plz help
there are jumpers on the rear of the unit and changing the position of the jumoer forces the computer to either a master or slave as it boots...on the rear panel it says cbl,sl,ms....ms=master, sl=slave, cbl=cable select...i hope this helps... also after done the jumper thing make sure your ide controller is on for the units on that cable...good luck my email address is troublerst at hotmail if you need further assistance....
Jul 15, 2007 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Please help
make sure that when you fitted the drive that the plastic jumper cap on the back of the writer was set to master if used on it's own IDE cable, or set as slave if it is sharing and IDE cable with another drive, you will find the master and slave positions either underneath the unit or above the jumpers at the back.
Jul 11, 2007 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Steamist System 18 2@9KW 240V 1PH - 1810-IM Logo
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
