Question about GE Spectra JGBP30 Gas Kitchen Range
I have a GE JGBP30 gas range. The oven is taking
I have a GE JGBP30 gas range. The oven is taking a long time to pre-heat. I can hear it go on, then off breifly, then on again, then off, etc. Eventually it will heat up and I can use it. Is the ignitor starting to go?
  • 1,543 Answers
Quiet possibly, but make sure there are leveling legs installed and the front edge of the range is not blocked by any flooring. It may be that the oven is not receiving enough combustion air. (sometimes happens when flooring is replaced and legs are removed so the range is not higher than the countertop, or a layer of flooring is added to the room and buts up against the range, where flooring was not added.)
Posted on Jul 04, 2010
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Broiler works - oven won't heat - smell gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | GE Spectra JGBP30 Gas Kitchen Range
Used the oven on Sunday night - on Monday it wouldn't work!
Check to see if the ignitor is coming on, you will see a bright orange glow in the burner area when you turn it on. If you don't, your ignitor is burned out. It is a fairly inexpensive item and fairly easy for the do it yourselfer. Just remember to unplug your oven before you replace the ignitor.
Mar 23, 2009 | GE Spectra JGBP30 Gas Kitchen Range
Temp isnt right
thanks for the question the problem is with the igniter i have had the same problem many times just not getting hot enough i changed the igniter and it was fine thanks the appliance doc
Mar 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Feb 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Gas GE Range
need to replace ignightor in oven
Dec 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Gas oven igniters
  If it is also a round ignitor it's the same.
Oct 24, 2007 | GE Spectra JGBP30 Gas Kitchen Range
The oven won't light, it is a gas oven. The top (broiler) lights but the oven won't light. Thank you.
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Oct 20, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Oven takes a very long time to heat.
Do your burners work ok when the oven is on? if not you may have low supply pressure to your range or the regulator may be limiting the gas flow. Also, I have a wolf gas range and it takes 30 minutes to heat to 350 as well, haven't timed it to 400. Has it always taken that long? Another thing to check is the door seal. If its not sealing it could cause a long preheat. If the door seal is smashed flat and/or not soft it needs replaced. Hope this helps.
Dec 16, 2006 | GE Spectra JGBP30 Gas Kitchen Range
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
181 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
