Question about Rival RC61 6-Cup Rice Cooker
How much rice and how much water do i use - Rival RC61 6-Cup Rice Cooker
  • 3,600 Answers
You can put 2 1/2 cups of water and and two cups of rice this will make 1 quart of rice, if you want the 6 cup then add 2 1/2 cups of water per one cup of rice.
Posted on Jul 04, 2010
2cup rice with 4 cup water. Why is the water boiling out of the cooker?
Way too much water! Use the same amount of white rice to water and a third of a cup more when using brown rice.
Mar 16, 2015 | Farberware Kitchen Appliances - Others
Look for national rice-o-mat model SR-3F
I have this rice cooker (it's very small) and the original instruction booklet:
HOW TO USE
1. Measure rice with measuring cup. One cup of uncooked rice will make about 3 cups of cooked rice.
2. Wash rice 4 or 5 times with fresh water in another bowl. Wash until water becomes relatively clear.
3. Put rice and water into the pan. As a rule, add water to uncooked rice in the following standard proportions.
2 cups rice to 2 - 2 1/2 cups water
3 cups rice to 3 - 3 1/2 cups water
4. Place the pan directly on the internal heating plate, and make sure that the pan is properly located on the heating plate by turning it slightly to the right and left as shown. (see CAUTION) . Before placing the pan in the cooker, wipe off water and moisture from the outside (especially the bottom) of the pan.
5.Put on the lid.
6.Insert the plug end into a wall outlet.
7.Push the switch button to the "ON" position. Make sure the pilot lamp is on. When the rice is done, the switch will turn off automatically, the lamp will go out and a click will be heard.
8.Even after the switch is off, leave the lid on for at least 15 minutes more. During that period, the rice will be properly steamed to a fluffy character by the retained heat.
SOME HELPFUL HINTS
• Always tasty rice
With your National Automatic RICE•O•MAT you can have uniformly cooked rice ... you can even cook rice to your personal taste and preference. Taste and degree cooked depend upon the quality of the rice and the length of time it is soaked before being placed into the cooker. Add more water than specified for softer, more fluffy rice; less water for firmer rice.
• Rice may bubble over ...
If you use too much water or if the cooker is tilted, rice may bubble over. To prevent rice from bubbling over, add water using the cup included (refer to How to use, Item 3.)
HOW TO CLEAN THE COOKER
Do not immerse the body into water or spray water onto it. Wipe it clean with a wet dishcloth soaked in hot water.
Nov 21, 2012 | Kitchen Appliances - Others
How many cups of rice do you put in when your water line is at 3
hi,
Tips on cooking rice:
You estimate first how many rice you are cooking then follows how many water you will be needing to cook it.
In an average, 1 cup of rice per person (depending on the persons appetite) = 2 cups of water. Rinse first the rice about 2 - 3 times to remove unwanted stuffs then start pouring and measuring the water.
Note:
1 cup rice = 2 cups water (common ratio), but there are also type of rice that requires more water or less water. You can adjust next time the water depending on the result. If the rice is a little bit hard then add more water the next time you cook. If the result is too soft then minus the water.
Hope you can cook now a perfect rice! Bon appetite!
Don't forget to rate me and thank you for using FixYa!
regards,
John
Jan 20, 2011 | Black & Decker Black Decker RC3406 6Cup...
Recieved one as a gift lost instructions how much rice to water
Check this procedure:
* Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
* Take care to use proper water to rice ratios.
* Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
TIPS:
# You may wish to tweak the "rice to water ratio" with experience - for example: for larger quantities of rice, you may find a little less or more than one and a half the amount of water results in better rice.
# One cup of dry rice grains cooked in this way is about sufficient to accompany a meal for 2 adults.
# If the rice is a major component of the dish, you might need up to 1 cup of rice per adult.
# Your base measurement doesn't need to be a cup necessarily - the key is to add 1.5x as much water as rice, whatever the quantity.
# It works best to use the original lid of the pot you use, since it will seal best.
# When the rice first boils, it might weep a bit or even lift the lid. Keep watch and an ear out for the start of the boil.
# These times and ratios are for white rice (e.g. Jasmine, Basmati, etc). If you are cooking brown rice you will need around 2C water to 1C rice and double the time.
# Salt is not necessary when cooking rice, but can be added. Unless you add a ridiculous amount of salt it will not significantly change the boiling temperature or time.
# Water boils at a lower temperature at altitude. If you live at a high altitude it will take longer to cook rice using this method.
I hope help with this (remember to rate this answer).
Sep 30, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Lost direction on how to use my rice cooker and havn't used it in a while
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Please rate this answer. Thank you.
Mar 27, 2010 | West Bend 86712 12-Cup Rice Cooker
I have a rice cooker with no instructions and need to know how much water per cup of rice
I have access to the Australian Owners Manual for this model if it would help.
It says:
Add water using the following ratios:
White Rice = 1cup water : 1cup rice
Brown Rice = 11⁄2 cups water : 1cup rice
Feb 06, 2010 | Breville RC16XL 6-Cup Rice Cooker
Rice is mushy, I have cut the water down by one cup and it is still mushy. 2 cups rice 4 cups water down to 3 cups water
If you are using regular rice, it is 1 cup of rice for 2 cups of water. Bring the combo to a hard boil and then reduce the heat to a slow simmer for 20min, stirring ocassionally.
If you are using "Minute Rice", it is 1cup of water to 1cup of rice. Bring the water to a hard boil, turn off the heat and add the rice. Cover for 5min. Fluff with a fork.
Feb 02, 2010 | Hamilton Beach 37532 20-Cup Rice Cooker
Need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
How much water
Well, the ideal rule of thumb is about 1.5 - 2 inches of water above the level of rice. Then again, it depends what type of rice you are cooking...But 1.5 inches should work.
Cheers!
IrishDruid
PS..Dont forget to assign a FixYa rating! Should you have any further queries, please post back and I will assist you as best I can :)
Apr 27, 2008 | Oster 3072 20-Cup Rice Cooker
Cooking rice
I have a Sunbean Instant Streamer model 4710... I just wash the rice, add it to the bowl and add 1 cup of rice to 2 cups water. I fill the the bottom of the streamer to the max line and turn the steamer to 50 minutes.. The rice comes out great in my streamer this way
Sep 08, 2007 | Sunbeam SUN-4710 5-Cup Rice Cooker
Rival RC61 6-Cup Rice Cooker Logo
135 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
