Question about Kenmore 53092 / 53094 Side by Side Refrigerator
My ice maker won't dump the ice....there is ice there but it won't dump...the water works fine.. help
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
SOURCE: Ice maker not dumping ice
Mine makes ice and does not dump it... unless the bin is out! I took out the bin to begin trouble shooting and had to stop to answer the phone. While on the phone, I heard the ice drop. Not sure how to fix it yet but it seems like the ice maker is lower than it should be.
Posted on Sep 21, 2007
  • 54 Answers
SOURCE: ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Posted on Feb 12, 2008
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
My ice maker quit working.
Ice not being dumped out because the heating element designed to slightly melt ice so arms can push it out is non functional and needs replacement. Cheaper and better to replace entire unit at nominal cost.
Feb 12, 2015 | Kitchen Appliances - Others
Ice Maker fails on occasions to dump ice before water is dispensed
monitor the cycle as it is filling water does it over fill or is there a seepage that continue to drip, it could be the water valve. Also do you hear the tray making noise as it tries to dump the ice "the harvest cycle" try to watch it to see if it is a mechanical gearing problem
Nov 19, 2013 | Refrigerators
Tfx20r ice maker won't fill
Try this fill the ice maker with tap water so we can decide if it is the ice maker or the water control valve. After the water freezes if the ice dumps and the ice maker does not refill with water then you will need to replace the=> WR57X10033 Water Control Valve If the ice maker does nothing after being filled with tap water and the water freezes then this would point to the=> WR30X10093 Ice Maker Assembly If you have questions I will be here to answer them for you, Thanks, Sea Breeze
Jul 06, 2012 | Refrigerators
My Whirlpool is not making ice cubes and the tray is dry, no water inside the ice maker but the water dispenser is working fine.
Most likely the water control valve on the rear of the refrigerator is defective on the ice maker side. Fill the ice maker with tap water and if it dumps the ice and does not refill then the water control valve is the reason. Usually an ice maker that still had cubes and will not dump the problem would be the ice maker. Hope that helped you, Thanks, Sea Breeze
Nov 22, 2009 | Refrigerators
I just replaced ice maker assembly because of broken plastic which holds drive gear. Now the new ice maker will not fill up with water. Water dispenser works fine.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 02, 2009 | Refrigerators
No ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
Aug 19, 2009 | Refrigerators
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
515 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
