Question about Car Audio & Video
When i hook up the tview dvd71ts all it shows on the screen is back view and the buttons wont work
I had the same problem when I installed mine. All I did to fix it was go back and rewire all of my connections and made sure no two wires were touching when they shouldn't have been. Ultimately, there is a back up camera wire on the stereo itself that was grounded out. So just check your connections! I hope this helps
Posted on Sep 18, 2012
  • Kanarius Lovett
    Kanarius Lovett Mar 15, 2015
    I have a tview D62TSH and nothing comes on but the lights
I have the same did you find out a way to fix it
Posted on Oct 12, 2010
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
Tview d72tsb screen not on
I'm having the same issue. the bottom buttons illuminate and can hear the cd.. just no sound through the speakers and screen stays blank..
Feb 06, 2012 | T-View Car Audio & Video
I have a tview in dash dvd player it is d7905bd I am getting no sound and it has a blue screen and the little screen says back c 4 r any solutions
if you connect the brown safety ground wire to the black ground wire it should start working, mine was doing the same thing and that got it working.
Apr 11, 2011 | T-View Dvd7905bd Car Video Player
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
No picture on tview dvd70ts
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Apr 08, 2009 | T-View INDSH DVD PLYR W/TUNR Car Video...
CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Jan 18, 2009 | T-View TView (T606HR) 6" TFT/LCD Monitor...
A/V AND Power wiring diagram
hi on what you have just told us go and get the same cables that you were using in the old car coz this wires are the ones ment for the screen i mean right holms,right jack pins for it . good luck .
May 03, 2007 | T-View T-6500HR 6.5 in. Car Monitor
Car Audio & Video Logo
157 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
