Question about Candy CPC220 Bottom Freezer Refrigerator
Fridge over cools - compressor keeps running -
Fridge over cools - compressor keeps running - all the indicators lights seem to work and the fridge light comes onas expected
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My Westinghouse freestyle fridge freezer is running but is not cooling the fridge at all.
there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Mar 19, 2011 | Refrigerators
Hi,I have a westinghouse fridge model RJ215M,have had it from new,it has just stopped cooling,both fridge and freezer also the fan,only thing working is the light,could it be the thermostat or the fuse....
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Feb 19, 2011 | Refrigerators
Freezer not working red light on indicating high temperature and fridge is starting to ice over, drinks forming ice in them
Top of Form
Oct 11, 2010 | Hotpoint Refrigerators
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
Defrosted it and now when plugged in, not getting cold.
If the compressor is running then it ought to cool. If not shut if down once again wait for few hours and keeping the thermostat in the normal position switch on.
If there is no cooling check if the compressor is working, If the motor speed seems dull check for capacitor being weak, gas pressure being down.
Though it seems strange that a defrosted fridge does not cool and we must suspect the compressor..
Sep 14, 2010 | Danby (DAR604BLS) Refrigerator
Ice does not come out
When an icemaker slows down , as long as the fridge AND freezer are cooling normally , it usually indicates that the coils need cleaning of dust , lint , pet hair , sand , etc...Also make sure the fan by the compressor is running to keep the compressor cool .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
May 24, 2009 | Victory URD-27-SBS Stainless Steel
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Candy CPC220 Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Billy Detlefsen
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
