Question about Danby DPR2262 Top Freezer Refrigerator
Danby DPR 2260-2 will not cool sufficiently
I have a Danby Fridge which works fine in the winter months but now that it is summer, it has trouble cooling enough. The ambient outside temperature is about 16 to 24 C. I've cleaned the chimney, the back of the frigdge and pipes etc. The flame is good strong and blue. I tried to invert, tap the pipes and let stand upright before start up. Not much success. After 12hrs of running it is still marginaly better then 16 C for the fridge and 4 C for the freezer.
Any ideas?
3 Suggested Answers
  • 108 Answers
SOURCE: Freezer works fridge not cooling on a Danby Designer fridge
There should be a vent between the freezer compartment and the fridge. In order for the fridge to be cold, this has to be open so that cold air can cool the fridge. I'm not sure, but I'm guessing that on that model it is simply a mechanical door operated by a dial. so you need to open any covering sheilds and make sure that the door (the damper actually) is open, and that air is blowing through. Granted, you don't want it open too wide, because then you will have two freezer sections, so you might have to experiment with it.
There is a fan in the freezer that should be pushing air... on some models the fan stops when the freezer door opens, so check holding down the door switch.
Posted on Jul 30, 2009
  • 906 Answers
SOURCE: Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
What weight oil to use in the summer in a 2003 pontiac grand am
heavier oils are fine in warm summer months, 10W30 or 10W40-
all cars ran on these oils summer or winter for years. Newer vehicles are designed for 5W oils and you should use a 5W oil for them in the winter months
Jul 15, 2016 | Pontiac Cars & Trucks
We have it in a summer home where power is off during the week. On the weedends, we turn on power and our fridge worked fine for the first month or so. Now the refrigerator portion does not cool down but...
the freezer takes first priority for cooling,then the fridge,the unit will take about 24 hours to reach optimum cooling even with the fast freeze button on.we used to have unit in garage with power on to unit permanently.using a power breaker in case of shorts etc......(f/f are supposed to be on permanently)
Jun 29, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Samsung fridge freezing the contents
is ther much frost in the fridge?if so, defrost (no hot water)
if not just turn down the thermostat to no 2. on scale of 1-5 poss cause... ambient air temp change from summer to winter i.e. turn it up in summer down in winter....
Feb 08, 2010 | Refrigerators
NDR 1292
Make sure the condenser fan underneath the unit is running when the compressor is. I don't know what else it could be unless the door gaskets are in bad shape.
Aug 20, 2009 | Dometic NDR 1292 Refrigerator
Leaking
Is there a condensate trap in the line before the discharge?
Also is the orifice or near it cracked?
With all the movement and expansion and contraction due to the temperature changes in the seasons and conditions, there might be a crack somewhere else.
Be ready with a Wax Ring for a toilet ( a new one ).
They usually seal it up fairly well.
Works for me until I can get a new pan.
God Bless.
Erik
Aug 08, 2008 | Danby Portable Air Conditioner
Maytag MSD2356AEW Side by Side Fridge not Cooling enough
Deforster not kicking in. There is a chip that is supposoed to kick in thte Auto Deforst on the frezzer side. It fails and the system freezes up and can not circulate cold air form the freezer side to the Fridge side. Simple repair, but yo will needed a service tech for this.
Jul 20, 2008 | Refrigerators
I have a Simplicity dehumidifier/humidifier model SHCC6026 by Danby, bought new, used 2 months last summer as a dehumidifier, was emptied and dryed before storing for the winter. On start up this summer,...
I contacted the Danby Co. and found out the unit was still under warranty. They gave me the name of a local repair shop who replaced the float sensor "free of charge".
Thank you for your time and interest. If I have another problem later I will be in touch with you.
mef
Jul 02, 2008 | Danby Heating & Cooling
Refrigerator won't work after winter shut down at camp
This is a problem we frequently run into in a situation such as yours. Refrigerators are meant to be used in continuous operation. Using them seasonally will let the high side condenser tubing, internal to most cabinets, rust through and loose the refrigerant charge.
May 03, 2008 | Kenmore 73503 Stainless Steel Bottom...
Danby DPR2262 Top Freezer Refrigerator Logo
373 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
