Question about LG WM-0532HW Front Load Washer
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
    New Friend:
The whose work : disassembly tub, old bearing, change new bearing and reassembly washer could take around 30 minutes NOT REALLY HARD WORK one you master....
Posted on Aug 11, 2013
  • 1,543 Answers
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Posted on Jul 04, 2010
2 Suggested Answers
  • 185 Answers
SOURCE: How to replace the Bearing Ball on A front load LG Washer?
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Posted on Aug 30, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
Does a 2002 taurus have wheel barrings
Possibilities are:
  1. Bad wheel bearing
  2. Bad tie rod
  3. Bad ball joint
  4. Bad strut
  5. Loose lug nuts
Most cases it's a wheel bearing but since you're getting a loud noise too, it could very well be a bad ball joint or tie rod end.
Oct 18, 2011 | 2002 Ford Taurus
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
My LG Front Load Washer is making a horrible, and loud, sound, esp. when it is spinning. Sometimes is also leaks a little too, as I find a puddle of water coming from under it!
Hi dear.According to your explanation,machine's drum bearing gone.That's why it's loud when it's spinning & leaks especially high water level.That needs to be fixed.Please consult service centres get quote & make your decision(It's a costly repair).I hope that helps.Thanks.
Sep 01, 2010 | LG WM1812C Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
Jul 04, 2010 | LG WM-0532HW Front Load Washer
I have LG washer and dryer and its making loud noise, specially when its spinning. Do you have any suggestion. this washer is only 4 yrs old
The most common reason for a loud noise on spin cycle is that water has got into the bearings and forms rust. The ball bearings are no longer smooth. Hence the noise!..Probably the most common F/L washer reason for demise. If the inner bowl is loose and 'floppy', it would be for the same reason.....Overuse of detergent will do it every time!.....Sorry.......Nomess
May 16, 2010 | LG WM3431 Front Load Washer / Dryer
Our neptune front-loader has become extremely loud during spin cycles, you almost need hearing protection, otherwise, it works great
Ball bearings have worn out. Replace as a set. Replace Water seals in the drum. Check the bearing shaft for any scrub marks. Check bearing housing. Fix new bearings now
Apr 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
988 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
