Question about Olympus Camedia Stylus 300 Digital Camera
Camera keeps showing card error - Olympus Camedia Stylus 300 Digital Camera
    Brigadier General:
  • 11,967 Answers
You may need to format the card in the camera. This will erase it so download any pics from it first using a card reader.
Posted on Jul 04, 2010
The camera keeps showing card error and unplug card. also shows format-yes-no. What is this?
Hi, it sounds like the card has an error and will not work properly if you have another card and you put it in and it works ok then that proves the first card had an error If you put the first card in and it asked you to format it what it does is it makes the card ready for use in your camera and if there is anything on the card and it formats it it will erase everything on the card. When installing a new card on a camera it will always want to format the new card and you let the unit format the card. In the end if you put a new card in and go through the format stage and the camera still comes up with error you have a fault with your camera.
Feb 12, 2016 | Cameras
8 gig sd keeps showing error?
What make and model camera?
Your 8GB card is actually an SDHC card. Is your camera compatible with SDHC cards or only with SD cards?
Oct 06, 2014 | Cameras
My memory card keep on showing "memory card error". how can I save my pictures in that memory?
You could use a separate card reader to download your pics. Then, format the card in the camera.
Jun 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
I keep getting a card error message when I turn the camera on
what kind of card are you using? If your not using SM media card you might consider buying one..but before you get a new one try to borrow from someone or try to put a different memory card and see if it still shows a card error message...
Jul 06, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Memory card error for my canon powershot a95 keeps showing up.
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
May 05, 2009 | Canon PowerShot A95 Digital Camera
Formating a 2GB picture card in my Olympus 565 4px camera
Try formating card on your computer using An adapter. by then it should reformat card, if error still shows on computer chances are card maybe defective. check card as well if its lock or write protected there is a white switch on the side of the memory card itself.
Apr 13, 2008 | Optimus DS-5080 Digital Camera
Memory Card Error
Check in the Manual that the camera can accept 2Gb.
If it say it can then return the card for replacement.
Feb 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Olympus Camedia Stylus 300 Digital Camera Logo
26 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
