Question about Garden
Motor starts and runs good till it warms up then as it warms up shuts down and wont restart till it cools back down
    Scholar:
  • 38 Answers
2 things to check are the ignition spark immediately after this shutdown, which would indicate a faulty coil, and loosen the gas cap to see if a vacuum is being pulled on the tank due to a faulty vent, which would prevent fuel from entering the carburetor, but chances are, on a riding mower this is either a faulty ignition coil or a fuel system issue. The best way to tell if it is a fuel system issue is to apply the choke as it begins to die and if it is running out of fuel it will pick back up for a little longer. If no change when the choke is applied then check the spark at the plug(s).
Posted on Jul 04, 2010
Tractor starts and runs well for 15-20 min., then why does it shut off?
Hey John!
Have you check the OIL some of these engine have a low oil shut-off sensor feature built-in ?
Check also that the fuel is not contaminated (Fresh Gas, please!)
Good Luck,
JP
Oct 28, 2015 | Garden
2000 suzuki vitara runs 15 min stalls wont start till cools down
Did they figure out if you are loosing fuel or spark when it fails to start up ? You would need to know which to proceed.
Feb 13, 2014 | Suzuki Grand Vitara Cars & Trucks
Quits after warm up wont restart
sounds like you have a fuel pump problem, fuel pumps will usually get hot and then shut off allowing it to sit 30 mins lets the pump cool down allowing it to start pumping, the way you can test it is get a can of starting fluid the next time it quits raise your hood and spray some fluid down into the throttle body and if it starts and then dies it is most likely your fuel pump, hope this helps.
Feb 02, 2013 | 1999 Dodge Dakota
Car wont start till it cools down
Does it have an external starter relay?(Fords are notorious for these going bad).
May 11, 2012 | Ford Escort Cars & Trucks
Hi i have a ready heater 170T i cleaned it last year to help out our main heater in our barn for when its get way to cold for our main heater to keep up so i turn this on when i am back there for the day...
Based on your description of the problem ............The part where you say "wont relight till it cools down" is a sign that the motor may be getting hot, the internal sensor in the motor is shutting things down for safety reasons. To find out run the heater til it shuts down then remove the cover. Feel the motor. It should be room temp or slightly warm. If hot- replace the motor with 102001-30.
Other possibilities would be a defective thermostat or temperature sensor. Eliminate these possibilities first.
Sep 07, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dryer will not start. has been just shutting itself off recently before cycle was complete. turned off this time and will not start again. we have back panel off and all wires look to be connected. any...
The most likely problem with your dryer is that the motor is defective,if it cools down and starts when cool then shuts off when warm and wont restart yet once again till cool the motor is the trouble. Also you may hear a heavy(ish) humming sound when it starts if motor is bad. Their is the thermal fuse that will make the dryer not start if it's bad its either good or bad and never intermintent like the motor will be.
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Dryers
Volvo 245 engine shuts down when warm.
done the same in my volvo it was disrubitor but make certain that replacement one the same part number.
Jun 26, 2008 | 1982 Volvo 240 Series
Htr shuts off after awhile and won't come back on till it's cooled down
I believe your heater has a solid state relay to start the motor when the motor gets to speed it is supposed to shut off. It may be stuck in the on position.
Jan 20, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
