My air cond. Quit working on my 2005 freightliner box truck replaced switch unit blower and checked freon still will not do anything
  • 3,600 Answers
Try replacing the low pressure switch on the accumlater and see if it works, does the fan work at all? if not then the module for the fan is defective and you will have to test the fan switch or the resister pack for the fan thats mounted on the heater box and is mounted by two bolts 1/4 inch diameter. the resister pack is 10 bucks. and only takes 5 minutes to replace.
Posted on Jul 04, 2010
  • 28 Answers
Which model you got?im a freightliner mecanic
Posted on Dec 11, 2011
Air conditioning problem
Air Conditioning problem
2004 Chevrolet Impala
Ac is not blowing out cold air. You have to put gages on the system and it shows its has freon.Checked all fuses and relays. The two fans in engingine compartment do not come on when the ac is turned on but does when the engine gets hot. The compressor engages when turned on also.
If the magnetic clutch engages the compressor and still no cold air could be still low in freon or the HVAC unit.
Blower motor not working all the time...if I bang the dash near the glove box, it comes on then works great. Is this the switch assembly, the resistor problem, or should I be replacing the blower motor?
Jun 04, 2013 | 2004 Chevrolet Impala
Air cond
sounds like a low freon charge look for leaks in the right rear corner where the lines go threw the floor to the rear unit
Jun 05, 2012 | 2005 Dodge Caravan
My 2005 ford ranger a/c is not working all the sudden, could it be a fuse?
My AC quit all of a sudden and it was a switch in the ac line. It was located on one of the air conditioner lines almost next to the firewall. Looked like a little box. When the p/u was running and the ac was turned on, I tapped it with a screwdriver handle and the ac compressor came on. I think it was a low pressure switch and is supposed to keep the ac from running without any freon, so you might try that. Best of luck.<!-- from fixya rte -->
Aug 11, 2010 | 2005 Ford Ranger
Air Cond. not working. Clutch does not engage
On the low port side (the side you put freon in) there is a low pressure cut out switch, pull it off and run a jumper wire across the two connectors, if the compressor kicks on the you are low on freon. and have a leak some where.
Jun 22, 2010 | 2005 Dodge Caravan
Not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
Dec 14, 2009 | Heating & Cooling
My air cond ic box not function well and i can only use switch 4 for the air cond cooling coil fan speed. switch 1, 2 and 3 recently cannot function at all. before this switch 2 and 3 works like switch 1...
You need an new blower motor resistor. I guarentee it. Ive seen this a 100 times. It is located under the dash on pass side by the blower motor. one big plug going to it.
Dec 02, 2009 | 1989 Toyota Camry
We have a dodge caravan, and blower motor quit working so i replaced it, it still doesnt work, is the only fuse panel under the hood
tn my 2005 Grand Caravan there is a resister unit located behind the glove box that also has a "thermal fuse link". This fuse is not replacable and if it blows your fan motor will not work. The replacment unit is $14.00 at Auto Zone.
Oct 21, 2009 | 2005 Dodge Caravan
2005 Chevy astro van, 4.3L A/c, Blower motor,
It could be a bad blower motor - tap on the blower motor with the end of a hammer when you have the switch in the on position - if it comes on then it is a bad blower motor. If it doesn't come on I would check to make sure you are getting power and ground to the HVAC control head.
Aug 04, 2009 | 2005 Chevrolet Astro
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Air cond will run for 1-1.5 min then stop , will restart after about 2-2.5 min
you have un under charged unit, under charged of freon. add some freon and check for leak of freon.
Jan 19, 2008 | Heating & Cooling
Heating & Cooling Logo
277 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
