Question about Canon MP560 All-In-One InkJet Printer
Our canon MP560 printer will not turn on - it was plugged into a surge protector and we have tried moving the plug to alternate outlets just to make sure that wasn't the problem...help!
This is what worked for me. I had a similar setup and could not get the printer to turn on. Remove the power supply from the back of the machine. It is a very simple process: pull apart two small plastic connectors with your fingers to remove power supply. Disconnect internal blue cable from power supply.
Replug blue cable and be sure it is plugged in tight.
Push power supply back into place, be careful of blue cable when pushing it back into printer.
Plug in and printer just may work...good luck!
Posted on Dec 13, 2010
Posted on Oct 24, 2012
Canon pixma mg5220 will not turn on
When you have sparks it toasts the chips even a good teck will ground themselves before opening a peice of equipment like that. I'm sorry to say but I doubt very seriously if either piece of equipment will work. I would also get rid of the surge protecter and have that outlet looked at.
Oct 14, 2015 | Canon PIXMA Office Equipment & Supplies
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
We moved our TV from it's normal spot (hooked into different power source and cable outlet) and now it's dead. It won't turn on at all. We moved it back to it's old spot and still no luck. We bought it...
If it was plugged in during a power surge without a surge protector, there is a possibility it could be dead. Or if it was plugged into a new outlet without a surge protector, especially if it was never properly shut off before the move, that could kill it. Try unplugging everything and letting it sit for 30 seconds, then try again (with a surge protector if you have one)
Oct 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Power overload with Brother HL-2170W
It might just have been that outlet in the surge protector is bad when you tried to use it, it might have shorted the system out
Aug 23, 2009 | Brother HL-2170W Laser Printer
Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Jul 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Canon MP560 All-In-One InkJet Printer Logo
3,595 people viewed this question
old marine
old marine
