Question about Samsung Televison & Video
I have a samsung 403t flat screen monitor. It's a few years old but it still works very well. I have a very good picture , but i can't get any sound. I have it hooked up to an high definition cable box with an HDMI cord . I have two computer speakers hooked up to it , but still no sound. The volume on the cable box and monitor have both been turned up and still nothing. Help !
  • David Dahwud Hughes Jul 04, 2010
    Thanks 4 the help. i believe you hit it right on the target. On to the next question
  • Samsung Master
  • 6,993 Answers
the fault should be from the sound IC of your TV. But before I conclude on that, get a earphone and fix it into the earphone jack of the TV. If there is no sound from the hear phone, the believe me, there is a problem with the sound IC/chip of the TV.
You need to dismantle the TV, get a meter, read the sound IC of the TV to confirm if the IC is actually bad or not. if its bad, then you will have to replace it.
Also, I have seen some Samsung TV's that has "Speaker Off" check the sound settings of your TV and make sure the speaker settings is not off.
If it ends up that the sound IC is faulty and you cannot do the replacement yourself, maybe you should visit the nearest repairman to fix it for you.
I wish you good luck.
Posted on Jul 04, 2010
    I fix personal computers as a side job . so i'm hoping that replacing the sound ic chip won't be that far out of my range of expertise. Where can i find the the sound ic chip and about how much does it cost?
I have a samsung syncmaster 403T lcd monitor..its working good in self tet mode..picture is ok.. working normally,the problem is when i connect to pc or any video signal suddenly work after goes to wh
Sounds like T'Con board fault. Contact any service technician. When video signal interfaces, it goes overloaded. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 23, 2014 | Samsung Televison & Video
Systematic diagram for samsung syncmaster 403t
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Schematic diagrams to power regulator board to many popular TVs are given. Here I can't attach it, as all of it are in PDF format.
Jun 25, 2014 | Samsung SyncMaster 403T 40 in. LCD...
I have a Samsung SMT-190 19" FLAT PANEL monitor and the picture won't show but a few minutes and then a sound comes on and the power light is blinking and the picture goes out and leaves only the blank...
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
Jul 13, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Samsung 403T no power
1) Fuse is good?
2) You must have 5vdc stanby voltage the minute you plug the set into the wall, this is a must have before going further. Please look for that first, then report back what you find. Pictures and Sch will be a great help. See example of my pictures here: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | Samsung 403T 40" LCD Monitor
My samsung syncmaster 941 bw just went white screen
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 05, 2009 | Computers & Internet
Samsung 953BW blue power lights just flashes when turned on nothing visible on screen with no computer connected
Buddy
Corporate Computer
www.ccl-la.com
Jul 31, 2009 | Samsung 953BW LCD Monitor
My LG LCD Monitor suddenly went black with no warning. Nothing shows up on screen. My Model # is L2046NV and the monitor is about 3 years old. What is my problem?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 13, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Screen is black
Buddy
Corporate Computer
www.ccl-la.com
Jun 30, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
