Question about Bissell SpotLifter 1716 Bagless Handheld Vacuum
I plugged in my spotlifter and nothing happens. I
I plugged in my spotlifter and nothing happens. I checked to make sure the outlet worked, it did. The little light comes on, but no motor???
  • 276 Answers
Please check to ensure the power cord is not damaged and the CID has been reset. For futher information about this call us when you are with your machine at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Posted on Jul 06, 2010
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
When I insert the hose into an vacumn outlet nothing happens. I tried pressing the reset button but still nothing.
First, make sure the unit is still plugged in.
2. Ensure the circuit breaker has not blown. This is easily checked by simply plugging another item into the outlet. If it has blown, flip it back on. If it continues to blow, there's a short in the cord or wiring of the vacuum.
3. Is it just one outlet, or all of them. If it's just one, it needs replaced.
4. Check the prongs on the hose, wands, and power nozzle to ensure they haven't shorted out.
5. Use a multimeter or continuity tester to check wires in the hose. Touch lead of the mm or ct to a prong on the hose, the other lead to the connector on the other end of the hose. Check both connectors. One should show continuity, the other will not. Repeat for other prong. If either prong shows zero, hose needs replaced.
6. Motor is burned out and needs replaced.
There are other problems that could cause this, so I recommend taking it to the Broan-NuTone dealer you got it from for them to check the vacuum for problems.
Dec 19, 2010 | Broan-NuTone CV353 Central Vacuum
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Bissell 1715-g spotlifter
www.bissell.com and search model # 1715. It gives you the option to see the owner's manual in PDF.
Dec 12, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell Spotlifter 1760 will not turn on
Unless you want to take it apart yourself and try to figure out the problem, I would buy a new one. This is obsolete and you can't get parts for it.
Mar 29, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Need directions for use
http://uk.bissell.com/images/UserGuides/1719E.pdf
This is a similar model to the one you have. Would give you some indication of how to use.
Nov 23, 2007 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell SpotLifter 1716 Bagless Handheld Vacuum Logo
48 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
