Question about Audiovox PVS21090 9" TV/DVD Combo
When dvd is inserted and tries to load, screen says "no valid disc"
  • Audiovox Master
  • 6,993 Answers
was it playing DVD discs before now?
I suspect that the laser (lens) is defective that's why it not loading DVD discs. This maybe as a result of dust being on the lens, or the lens is no longer sharp. That is, the lens may have worn out, thereby not having the capacity of loading DVD discs. It takes a very sharp and active lens to play DVD discs.
Get a lens cleaner and use it to clean the lens. If that doesn't solve the problem, then it means you need to replace the lens.
Let your attention focus on the laser (lens) because that's where the fault is coming from.
Good luck.
Posted on Jul 04, 2010
  • amy9309 Jul 04, 2010
    do you think it's possible that the lens is just broken - it has hardly been used...
    if so, is it worth getting a new lens? and how/where do you do that?
    thanks
  • Walesarumi
    Walesarumi Jul 04, 2010
    if you don't often use the lens, then it might be that dust is on it. Get a lens cleaner like I stated earlier and if that doesn't solve the problem, then you will have to dismantle the unit, remove the lens, use the lens as a sample to get another lens. Go to any electronics accessories shop within your vicinity and get another lens.
    You can also manually clean the lens by using cotton board to clean the surface of the lens directly.
    Take care.
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
When the disc is loading it stops and says
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
Oct 20, 2009 | Venturer 3.6" Portable DVD Player
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
No Valid Disc
I had tried cleaning the lens like most solutions said to do, with no luck. I tried what user gthumm said he/she tried, which was taking off the back of the player. Their problem was the white wheel (motor) and the next wheel (black) were not turning smoothly. He/she pushed the white wheel down until it snapped back in, allowing the wheels to turn. I tried it twice and finally, I have a working portable dvd player again! Yeah! Thank you so much gthumm and fix ya team! My kids especially thank you! You are the BEST!
Dec 06, 2008 | Car Audio & Video
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
No valid disc
Hi, Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional. Good luck and kind regards.
Sep 28, 2007 | TruTech PVS12701 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Audiovox PVS21090 9" TV/DVD Combo Logo
41 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
