Question about Belkin (F5D7230-4) Router (587009)
My Belkin router says it's connected to the internet but when I try to connect an app on my i-touch it says no internet connection. Why?
Mtnhorse
SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Posted on Aug 18, 2007
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Posted on Jun 19, 2008
SOURCE: no internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Posted on Jan 21, 2009
  • 67 Answers
SOURCE: Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Posted on Mar 28, 2009
SOURCE: I have Belkin F5D5231-4 router. My DSL modem is connected to the
problem solved!
Posted on Mar 30, 2009
Connection error appears as i connect to the internet in Belkin wireless router in my itouch. I touch on the settings and tried to connect with Belkin. But there's a lock symbol in it. Then I tried to...
It is locked because there is wireless security enabled on it. Do you have the passcode? you can reset by going to the default ip address of the router. There should be no other reason for it not to let you connect and should in fact prompt you for a security key. If you still have problems go to Settings > General > Reset > Reset Network Settings on the deice and then hold the power button until you are prompted to reboot the device and then do so. After this restart the setup process.
Mar 03, 2011 | Belkin Basic Wireless Router
My belkin basic router is not working
well you can fix such kind of problems via contacting to belkin tech support. for more help you may visit: Belkin Tech Support Helpline
Sep 10, 2010 | Belkin (F5D5231-4) Router
Belkin N+ keeps dis-connecting from internet
u can try dowloading the latest firmware for the n1vision router...
here is the link.... http://en-us-support.belkin.com/app/answers/detail/a_id/503/p/328
download appropriate version and save in the hard disk.... login to router page... type 192.168.2.1 in internet explorer... password leave it blank and click submit.... click update firmware on the left....select browse and update the firmware dowloaded... after updating, login to the router page again and click on restore factory defaults(must)....your problem ll be rectified....
Feb 24, 2010 | Belkin N1 Vision Router
I have a belkin54g router and my touch connects to that, but no details come up and when i try and access the internet or my apps, nothing. . help! . . weirdest thing is thou. . it used to work fine and...
Yes, Your right.If your other wireless device able to go online means your router is fine... You need work on with Touch...Or try access other unsecured wireless network and check ...
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
When i try to connect my ipod touch to my belkin wireless router, it will not connect after i enter my password. i am able to connect my laptops and the wii with this password.
Open RSP by typing 192.168.2.1 on the Address of the Internet Explorer
Change the Security Mode into 64 Bit WEP
And also Disable Wifi Protected Setup
Dec 26, 2009 | Belkin F5D7234-4 Router
Unable to connect Ipod Touch to Internet via Wifi
im no sure wa kind of router i have, bu iam sure that i have the right password and i comes up with the networks i could connec to and i try connecting to my home 1 and it comes up "unalbe to connect to this network" my sis or my mum can connect either we all have ipod tocuhes and its getingfustrating. can any one help?
Nov 16, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
