Question about Pool & Spa
I have a jacuzzi platium(cfr 100) series motor pump and filtering system on my above ground pool.the motor a.o.smith 1.5hp just went bad and when I went to disassemble motor and pump does not want to come apart. I am looking new pump and motor assembly that will fit.the info on the motor is ao smith 1.5 hp spl 2- speed serial # bx11-11 60 hz frm R48Y volts 115 part no. 7-181327-03
john224
  • 1378 Answers
SOURCE: A.O. Smith motor for Jacuzzi Spa, 1 HP 2-Speed
Check the line voltage under load first to be sure it is not dropping to low and if it checks out, yes, get a warranty replacement.
Posted on Oct 22, 2009
john224
  • 1378 Answers
SOURCE: where can I get a guide for rebuilding my ao smith
You won't find one and rebuilding a motor of that nature would be a waste. For starters, once they fail to the point you notice they need atention it is usually to late. Parts are not going to be available and the cost of the replacement is so low it just doesn't make sense to try. A replacement motor is only about $130. If you would like a formal quote or to order one, contact us at www.arrowmotor.net and include the model number (326p203) in your message.
Posted on Oct 31, 2009
MOTORWIZJ
  • 1339 Answers
SOURCE: need ao smith replacement motor
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Posted on Aug 20, 2010
MOTORWIZJ
  • 1339 Answers
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
Posted on Aug 23, 2010
john224
  • 1378 Answers
SOURCE: My pool originally had a
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
Posted on May 24, 2011
Owners manual for cfr-50
in from pump to skimmer out from pump to filter in then filter out to returns
Jun 22, 2014 | Jacuzzi Filter Body,Cfr - 25
My pump is not primeing
most pumps that won't prime are not recieving a good seal on suction line (inlet) ck alll the fittings for good o-rings and ck filter lid as well , hairline cracks too can develop in hard plastic over time and rough treatment this can lead to loss of prime , one other reason and it's the most expensive reason is pump seal at drive end has went bad and sucking air if your handy with a wrench then you can source a new seal from jacuzzi if not replace entire pump (thats the expensive way)
May 10, 2014 | Jacuzzi Magnum Force Series Pool Pump 1...
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
My electric motor went bad and i am trying to replace it but can't remove it from the pump housing
you do not want to replace the motor only, the pump is handled as a unit... there are seal issues, etc.
Sep 05, 2010 | Jacuzzi Magnum Force Series Pool Pump 1...
After replacing gasket on filter vacumed pool
I would suspect that there is a fault in the filter, a bnreak in the filter elements, a bad alignment, a colapsed support. something that is letting the dirt get back in to the pool
Feb 11, 2010 | Hayward Pro Series 18" Above Ground Pool...
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Apr 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pool & Spa Logo
148 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
