Question about Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series washer the start/pause button flashes waiting to be pushed to start. Push button and nothing happens it just continues to flash under any setting. Could the push switch be bad?
  • Bosch Expert
  • 414 Answers
It's a possibilty, but it could also be the door lock or latch.
Posted on Jul 08, 2010
My Kenmore H2 Plus needs to be reset to factory settings. Cannot find how to in the manual.
Not sure if this will work with this model but try this:
1-Turn off and unplug the machine. Plug the washer back in and wait for the control panel to light up. This resets the washer back to the original factory settings.
2-Unlock the control panel by simultaneously pushing and holding down the Options and Select button for 10 seconds if you see a lock icon on the control display.
3-Push whichever new options you need, and wait for the control panel to flash and reset the washer's options.
Apr 22, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Bosch washing manchine nexxt 300 series, when i push the on button it will not come on
Check door switch. If OK then your probably looking at a motor control board problem. Ck connections on it. It is located in the back right corner of the machine.To get to it take the back off and it will be on the bottom left.
Mar 04, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Panel lights are on. push on button nothing happens
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
Apr 22, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
500 series washer
Hey try this, open the doo rand oil the door lock mechanism. next turn the machine on and push start/pause button. repeat ,repeat, repeat. if it does not release open round acees door at the bottom of the washer,there should be a manual unloccking pull inside pulldown to unlock(very thin strip of plastic. repeat process. also make sure rubber gasket around tub is secure and flush around washer openig.
Aug 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 300 Series WFMC2201UC Logo
339 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
