Question about Olympus FE-190 Digital Camera
Every time I turn on my camera a message appears on the screen that says "write protect". What is "write protect" and how do I get rid of the message?
    Guru:
  • 1,705 Answers
1) It could be your camera has write protect switched on. Go through your camera's menu and look for picture protect and remove it.
2) Your SD card could be write protected. Take out the SD card and check, there's probably a sliding notch on the left hand side, move the to write enable.
Posted on Jul 04, 2010
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
As I turn on the camera, a message of "this card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 06, 2011 | Casio EXILIM 8.1-Megapixel Digital Camera...
When I power up the camera, an image appears and
This old picture is on your internal memory. To remove it, remove your memory card...turn on the camera...go into the menu and find "format"...follow the on-screen instructions.
Dec 26, 2009 | Pentax Optio S5z Digital Camera
Protected card message
on the side of some picture cards there is a little tab that slides back and forth. If your card hs this try sliding it the other way. These are a write protection so to speak, or a lock in a sense
Jan 11, 2009 | Fuji FinePix A900 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Olympus FE-190 Digital Camera Logo
650 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
