Question about Dishwashers
Kenmore 665.13823 dishwasher couldn't stop a washing cycle. It was identified as "control board" issue. Is it possible to fix the circuit board/timer insted of replacing the board? Also, where are the mayjor screws located to open the housing for the control board? Thanks
  • doublewood77 Jul 04, 2010
    Thank you. The solution was helpfull.
  • 10,515 Answers
Unfortunately there is no way to repair circuit board or timer.
The procedure to replace control panel is :-
Step 1 Disconnect the power supply to the dishwasher by turning off the circuit breaker. The circuit breaker to the dishwasher is inside your home electrical panel.
Step 2 Open the dishwasher door and hold your hand under the center of the control panel. Using a Phillips head screwdriver, remove the six screws from the upper inside door panel that secure the control panel to the dishwasher.
Step 3 Pull the control panel forward to disengage it from the dishwasher door. Be careful when doing this because the control panel will still be connected with wires leading to the components inside.
Step 4 Label each of the wiring harnesses with masking tape. The wiring harnesses look like blocks of white plastic with wires inserted into them. Remove each harness from the back of the control panel. To remove harnesses, press in on the locking tabs and pull them apart. For wires that slip over component terminals, use needle-nose pliers to pull the wire leads off of the terminal ends.
Step 5 Pull the control panel completely away from the dishwasher.
If you wish to have the service manual, you could buy it from :-
http://cgi.cafr.ebay.ca/Whirlpool-Kenmore-Dishwasher-Service-Repair-Manual_W0QQitemZ260487648999QQcmdZViewItemQQptZUS_Nonfiction_Book?hash=item3ca64616e7&ssPageName=RSS:B:SHOP:CA:102
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 04, 2010
    Thanks taran_2005. I appreciated your instructions in such details. Also, how/where to order the replacement part (control board/timer) for kenmore 665.13823 dishwasher?
  • taran_2005
    taran_2005 Jul 04, 2010
    Thanks for your response!!
    It could be ordered at :-
    http://www.repairclinic.com
    http://www.sears.com/shc/s/c_10153_12605...
    Note - The problem that you mentioned could be due to many other reasons. If you are sure that the problem is due to control board / timer, then only order it as these are non refundable items.If you are in dilemma, better to call up a repairman.
    Hope i helped you.
    Thanks
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
WHy does my dishwasher not go beyond the wash cycle?
Sounds like a bad control board. Try turning the breaker off for a few minutes and try again. If that does not fix it you need to change the control board.
Dec 18, 2014 | Kenmore Dishwashers
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Jul 19, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore Ultra wash ll
sounds as if you may have blowna fuse on the control board, i would check incoming ower supply first for 110v. if power supply is good i would reomve the panel and check the circuit board for a a fuse that might have blown little white fuse attached to the side of the electronic control
Nov 08, 2008 | Kenmore 15129 Built-in Dishwasher
Whirlpool dishwasher
fuse on control board.
Jan 11, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
