Question about General Electric WHDSR316G Top Load Washer
I have a ge washer model whdsr316goww the machine will spins real slow will not pick up speed can you tell what to do
ginko
  • 19396 Answers
SOURCE: GE WASHER MODEL NUMBER WHDSR316GOWW,
Here you find all parts for your appliance.
Click on the diagrams to get the exploded view.
Posted on Sep 02, 2008
mumma_1
  • 903 Answers
SOURCE: noise when ge washer put in spin mode
this could be one of two problems.
The first which is fairly cheap to repair would be to check the carbon brushes in the motor, they may need replacing, especially if your washing comes out wetter then it should.
The second is the bearings on the drum which is more expensive to replace and would need to be done by an engineer.
Posted on Nov 16, 2008
  • 21 Answers
SOURCE: GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at thadoggma420@hotmail.com
Posted on Jan 22, 2009
  • 13433 Answers
SOURCE: spin speed too slow
When the clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 03, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
I have a GE commerial coin-operated washer, model no: WCCB1030HOWC. My question is about "the speed of washing". When it's washing, the washing speed is very slow (slow than the general home-use...
Ive got a couple of the same model. They do agitate slower than previous models a couple of years older. I have gone as far as replacing the motor and got the same results. I can only assume that they are operating as Ge intended.
Oct 07, 2010 | GE WCCB1030 Top Load Washer
Hello my ge washer spins real slow and will agitates real slow? it does drain the water but when it goes into spin and rinse spins real slow
The problem may be either the clutch or worn belt. I am including a link to a repair manual to better help you in repairing and diagnosing the problem.
www.appliance-repair-it.com/GE-washer-not-running.html
Aug 05, 2010 | GE WBSR3140DW Top Load Washer
Clothes are clean but soaked. Very slow spin
Clean out the drain pump AND connecting hoses.
Aug 30, 2009 | GE Washing Machines
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
GE 5500 washing machine TERMS
These are the agitator and spin speeds.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
General Electric WHDSR316G Top Load Washer Logo
237 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
