Question about Cell Phones
How can i find a charger for my BlackBerry phone
My blackberry bold keeps showing a battery with a redline on the screen instead of booting.
the device is drained to the bone this should go away and boot after 30 minutes max. I'm assuming you are using the original blackberry charger using a charger that fits but doesn't match the voltage/amperage that the blackberry charger outputs you wont be able to get rid of the drained battery screen if your blackberry haves juice you can use a non-approved weaker charger but that screen means it needs the original....also the blackberry USB is lets the same amount of electricity
Apr 09, 2011 | RIM BlackBerry Bold Smartphone
Tip
My AT&T Blackberry Curve does not charge anymore, is it the battery or the...
Hi.
Here a series of useful answers to common questions asked when an At&T Blackberry is not charging anymore.
1. My Blackberry is not charging anymore. Is it the battery or the charger?
Possible reasons are faulty battery, defective charger, bad contact on phone socket to charger.
When it is a charger problem, or a bad contact to charger, the phone will not detect that the battery charger is connected.
When the problem is the battery, usually you can see the charger beingdetected, and the charging line progressing, but the battery nevercharges.
The charger can also be tested using a Voltmeter. If the charge is in good working order, the Voltmeter will read a value within half volt from charger specifications.
2. Do batteries actually lose ability to work?
Yes they do, and the fault is not unusual.
3. How much will a new battery cost?
Most ordinary Li-Ion batteries for BB are sold at less than US$10. You can see a choice of sellers here: Blackberry Curve Battery
Ensure that the battery is compatible with your Blackberry model.
4. How much will a new charger cost?
The charger is also commonly sold at less than ten US$. You can see a choice of sellers here: AT&T Blackberry Curve's charger.
Ensure that the charger is compatible with your Blackberry model.
5. Will AT&T service the phone?
They will do, providing that the phone is still under warranty. Newwireless devices like your BB carry a one-year warranty from date ofpurchase. Refurbished devices carry a ninety-day warranty from the dateof purchase. If the phone had been purchased in US, to make a warranty claim after the first 30 days from purchase, you can call At&T at1-800-801-1101.
If the phone warranty has expired, a good choice could be going to anAt&T licensed phone shop, and asking to test battery and chargeron the bench before buying a replacement battery.
on Feb 18, 2010 | AT&T Blackberry Curve 8300 Smartphone
Hi there I have a blackberry 7230 Rim. but does not seem to charge also cant ring and send messages as the phone says low battery.
Either the phone is not getting a charge from the charger or the battery won't take a charge and is bad. You can check the charger by connecting it to the phone and seeing if the phone senses the charger. You could also try someone else's charger. If it is the battery you will need to replace it. Make sure the connections where the battery inserts into the phone are clean and the connections on the battery are clean as well.
Nov 19, 2010 | RIM BlackBerry 7230
My blackberry outlet carger on my phone will not carge my phone ithink its broken what do i do
This depends on what you are willing to do. The first and recommended solution is to buy a new charger. If you have one of the latest Nokia phones, the same charger can be used to charge a Blackberry. (Note: This has been tested by me on a Blackberry Curve 8520, using a Nokia N900 charger. Both have the same ends, for which I only use one charger to charge both, and one USB cable to upload files to both phones.)
Oct 25, 2010 | RIM BlackBerry Pearl 8100
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Hi in my blackberry pearl appear a battery with a red line in the screen and it does not function
it probably means that your charger isn't charging your phone fully. you need to consider getting a new battery and charger.
Oct 15, 2009 | Cell Phones
Blackberry world edition, will not charge...
What you can do is use the usb cable that came with your phone and hook it up to the computer to charge this will work unless there is something wrong with the phone itself the second option you could do is buy yourself a travel charger you can plug into the wall :).
Jun 22, 2009 | RIM BlackBerry Bold Smartphone
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
Hi, My charger for blackberry curve 8310 is not working . I have warranty . I purchased on November 2008. Can I get new charger for my phone?Will it be covered in warranty or I need to pay for it?
Bring it in to your local reseller, and have them test it with a charger they have there. They will hook a new adaptor up to it, and be able to see if it is the charger or the port. Either way, it's covered, as it is a simple fix.
May 01, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
SPRINT BLACKBERRY PDA SMART PHONE 7130E
When you plug in the charger, does a light come on, or is there a battery icon on the screen?
If not, then the charger is bad.
If it is, then either the battery or the phone is bad.
I've seen bad batteries do this, so make sure you check that before replacing the phone.
Let me know if this helps,
Simon.
Nov 20, 2008 | RIM Blackberry 7130e Smartphone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
