Question about Kodak Easyshare C813 Digital Camera
My camera says internal memory is full. I just put in a new memory card. Now what??
  • kakima Jul 04, 2010
    Internal memory is completely separate from memory cards, just like you could have a full glove compartment in your car without having a thing in the trunk.
    Check the camera's image storage location. Press the Menu button then use up/down to select "Image Storage." If it's set to "Internal Memory" then the camera will store images to internal memory regardless of whether or not you have a memory card installed. If it's set that way, change it to "Auto." In this mode the camera will store to a memory card if available, to internal memory otherwise.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Aug 09, 2010
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
CARD FULL with 3 pictures
Have you tryed eraseing / formating it in the 740?
Make sure the camara uses the card instead of internal memory
it might be that its saveing the images into the cameras internal memory witch is probably just about 3-4 shots.
Mar 09, 2008 | Olympus Stylus 740 Digital Camera
When a put a new memory card in the camera it keeps saying memory full how can i get rid of that
The camera is not seeing your new memory card, the memory full is referring to the cameras own internal memory. go into the menu and try to find the function that changes your memory from camera to the card.
Mar 10, 2011 | Samsung Digimax S700 Digital Camera
Brand new camera, unable to take any pictures. Internal memory is full. Even when we put a mmory card in place, still thinks internal memory is full. Why doesn't the camera use the memory stick to save...
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Dec 28, 2010 | Kodak Cameras
CAMERA SAYS INTERNAL MEMORY FULL. I PUT NEW CARD IN. STILL SAYS INTERNAL MEMORY FULL
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
Nov 25, 2010 | Kodak Easyshare C190 12MP Digital Camera...
I have taken 8 pictures with my camera and we had put in an 8gb memory card, but my camera says internal memory is full. this is a brand new camera, and I am learning about it, but why is the memory...
Apparently, you used the internal memory before putting in the memory card. Now the camera only wants to use the internal memory. Here's the fix...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the memory card. If this is a new card, you will need to format it in the camera, too. If there are any pics on it, download them first using a card reader if necessary, because the card will be completely erased.
Jul 27, 2010 | Kodak EasyShare M530 Digital Camera
I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
Apr 22, 2010 | Samsung NV3 Digital Camera
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
The camera doesn't accept new memory card put into the camera
Sorry that this answer is far too late to be of use to you, but it may help others searching for advice with the same fault. I only stumbled across your unanswered question by accident.
8GB is an SDHC card. Your camera was designed to use the earlier SD cards instead with a maximum 1GB capacity.
Dec 07, 2008 | Kodak EasyShare C533 Digital Camera
MEMORY FULL
Talking about the Camera only here Check the manual for internal memory use. Put the memory card in. Use the menu button to switch between internal and card If your computer is XP you do not actually need any software to read the camera. Check the manual re this
Sep 27, 2007 | Samsung i70 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
99 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
